Quick update
-Launched NDS and went in idle/timing mode.
-Timing light is steady on the last notch.
-Timing in NDS is at 20
-Idle is at around 1300 and cannot drop it with the iacv screw. Cannot get the 750rpm...
-Sometimes drop to ~1100 and timing drops to 8 on NDS.
-Pinched the hose and the rpm dropped...
IACV again ?
Cams swap installation, no start
- redpotatoes
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
- redpotatoes
To set base timing and work from there.
Before I swapped the cams it was set at about 950-1000 and that's were I want it again.
- redpotatoes
- redpotatoes
Fixed, went for a ride, did few logged pulls with the new cams. Came back home, idle at 750-800 @ 20 timing in NDS and on the crank.
- redpotatoes
