dual cam w/o power steering belt
datsunissan
Post by datsunissan » Thu Apr 04, 2013 12:03 pm
exactly what the subject says..i have a 95 ka24de that i took the ps pump off of and im wondering what i need for a belt. someone said something about a single cam pully but hopefully i can just buy a belt nothing crazy. help plz
thanks
Re: dual cam w/o power steering belt
Post by beercandrifter » Thu Apr 04, 2013 12:21 pm
datsunissan wrote:exactly what the subject says..i have a 95 ka24de that i took the ps pump off of and im wondering what i need for a belt. someone said something about a single cam pully but hopefully i can just buy a belt nothing crazy. help plz
thanks
grab piece of string, wrap around the pulleys to form full circle. measure length of string
take measurement in to autoparts store and they can hand you a belt by length.
Post by airman » Thu Apr 04, 2013 12:45 pm
String method will get you close but might be too tight.
Anyways, this is what you want.
viewtopic.php?t=34921
I don't remember exactly what belt I used. I did have to get it in a 4-rib and cut it down to 3-rib because the stores around me don't stock a 3-rib in that length.
i_slide
Post by i_slide » Thu Apr 04, 2013 1:12 pm
Part #s:
Ac Delco: 3K267
Carquest/Gates: K030267
Dayco: 268K3, 5030268
Goodyear (Gatorback): 4030267
Metric: 3PK0648, 3PK675, 3PK680
Motorcraft: JK3-274
Napa: 25-030267
Go with the NAPA brand trust me it's the best fit. This will run the water pump off the crank pulley without any tensionor needed.
kacam24det
Post by kacam24det » Fri Apr 05, 2013 5:08 am
Cam
Berserker
Post by Berserker » Fri Apr 05, 2013 8:00 am
Single belt from autozone, tight fit but got it on had it for 3 years or so.
nismoautoxr
Post by nismoautoxr » Fri Apr 05, 2013 2:10 pm
future reference . Take your old (too long belt) , put the adjuster in the middle of its range cut the belt, stretchit around the pulleys you want to engage cut the excess out till the ends meet and the slack is out then measure end to end . A string might get close but (especially if its a v belt) it falls too deep in the grooves to be accurate.
Ricky Ragan,
datsunissan
Post by datsunissan » Mon Apr 08, 2013 8:08 pm
thanks a lot guys. i think im gonna go the easy way out and either go with what berserker or i_slide said
Post by airman » Sun Apr 14, 2013 7:23 am
I tried using just a belt without a tensioner, not my cup of tea. It kinda worked but I didn't trust it so I ran it until I got my SOHC stuff. Definitely worth it. I only wish I could find the belt I needed for it with only 3 ribs instead of four.
