Dc sport strut hitting the valve cover
240sx-venezuela
Post by 240sx-venezuela » Sun Apr 07, 2013 6:29 pm
Hi, I bought a Dc sport front strut, but after intalled I've noted that it hits the valve cover, do anyone know what is causing it? Is it normal?
Post by cleantune » Sun Apr 07, 2013 7:30 pm
maybe the motor mounts sit to high? Are the motor mounts aftermarket? Do you have any pics?
240sx-venezuela
Post by 240sx-venezuela » Sun Apr 07, 2013 7:48 pm
Motor mounts are stock, the strut brace hits the letters in the valve cover, Ill post some pictures later because the car is in a dark area and my phone has not flash.
MasterOSkillio
Post by MasterOSkillio » Mon Apr 08, 2013 11:34 am
that's weird, I have a strut tower brace, and I just finished re installing the nismo motor mounts. Those are known for being higher, and everything still fits fine. There has to be an 1-1.5" of clearance there.
Are you sure it is the right strut tower brace for your model/year? There should be a little clearance, honestly I wouldn't run anything that had less then 1" clearance from the motor. Especially with stock mounts, those things allow the engine to move around so much, it will rub and maybe crack the valve cover/brace, or do something worse.
240sx-venezuela
Post by 240sx-venezuela » Mon Apr 08, 2013 1:37 pm
Maybe the motor mount are cheap ebay mounts, do anyone the height of oem motor mounts to check?
Poor quality picture
Freise
Post by Freise » Mon Apr 08, 2013 1:53 pm
I've got the same strut bar but for S14 (they are slightly different) but even at the highest point there's at least an inch of gap between strut bar and vc. I would assume something weirds going on with the motor mounts
95 240sx KA24DE-T
S15 Injectors
Z32 blow through
Post by cleantune » Mon Apr 08, 2013 7:14 pm
Can it be installed if it was rotated horizontally 180 degrees? ...and is it definitely for a 240? (there should be a serial number somewhere on it, and if one contacts DC sports they should be able to tell one if it is the correct one; or could try looking it up on their product page on their website)
240sx-venezuela
Post by 240sx-venezuela » Mon Apr 08, 2013 7:44 pm
Stamped number in the strut bar is csb1205 so Ive checked and this is the correct part number for my s13
240sx-venezuela
Post by 240sx-venezuela » Tue Apr 09, 2013 9:54 pm
Im going to check the motor mounts height, and switch them, I think there is nothing worng with the strut brace, Ill let you know
