I am currently running the exhaust setup below on my 50 trim setup:
2.5" JGS Downpipe > 3" SR20 Downpipe (midpipe) > 3" Resonated test pipe > 3" CXRacing Catback with built in resonator.
The tone of the exhaust is awesome. Its a bit loud, but its got a deep sound with no raspiness at all. My main issue is that it seems to get even louder and resonate pretty badly between 3000 and 4000 rpm. I daily drive my car so I spend a lot of time in this range. I'm within this range for a while on my commute to/from work every day. I would love to quiet my exhaust without hacking up the SR20 downpipe or the cat back, so Im looking into replacing the resonated test pipe which is only about 12" long.
I have two options right now.
1. Replace the test pipe with a 3" High flow cat.
Ive read that the restriction would quiet the exhaust a bit, but would also cause some power loss and increase spool time.
2. Replace the test pipe with a Flowsound 1 chamber race muffler.
There aren't too many mufflers with a 12" overall length, and this is one of the few I could find. It does not contain any sound absorption material, so im afraid it may not help reduce the sound much.
Does anyone have any experience with this muffler?
Would the baffles reflect enough sound to lower the overall sound by a decent amount?
I am honestly leaning towards the high flow cat, but would like to hear some opinions.
I would prefer too quiet over too loud. LOL
Exhaust Suggestions
Exhaust Suggestions
Turbonetics 50 Trim T3/T4 .63ar
JGS Log Mani & Downpipe
Turbonetics Wastegate
Greddy Type RS Blow Off
PLX Wideband
Prosport Boost and Oil Gauge
CalumRT
WRX STI Injectors
PLX Wideband
CalumRT
WRX STI Injectors
Re: Exhaust Suggestions
your turbo will not like a baffled/chambered muffler.
Put a glass pack in place of the test pipe. IIRC when you place a resonator close to the engine it has more noise reduction.
Go faster or slower
Go faster or slower
I had the same problem
my exhaust
2.5" elbow > 2.5" downpipe > 2.5" resonated test pipe > 3" cat-back > 3" Dual Muffler
after I installed silencers into the muffler the deep tones went away, well and the whole exhaust sounds a lot less deep than before
here is a video, but it sounds different in person, since camera can't record deep tones
http://youtu.be/1u8HWScquXw
my exhaust
