car will not start...
- 500hpKA240sx
Ok guys I cant seem to find what the fcuk is going on with my 40...I drove it to work, left for lunch, and then drove home with no problem at all. I woke up to go to work and would not turn over at all just clicking, so I figured the battery went dead from it getting so cold out side and put the charger on and still just clicking. I have checked battery connections, starter, replaced starter solenoid, wires are all tight, it just doesnt make any sense. only thing left is maybe a broken wire which I read the black and yellow stripe wire that hooks to the solenoid may be the cause but it wasnt broken...it was an auto to 5 speed swap if that matters or means anything, and I feel a tapping in the clutch pedal when I try to start it and the clicking noise occurs... anyone ever had this problem? also if i pop start it with the key in the on position it will fire right up and run with no problems.
Re: car will not start...
did you try the old hit the starter with a hammer/pipe trick? I had issues like this before and hitting the starter fixed it temp. Ended up being the starter - even though it would spin free out of the car, once it had a load on it, just clicks.
Yep, sure sounds like a starter solenoid problem.
- 500hpKA240sx
I pulled the starter and put a new solenoid on a brand new starter maybe 800 miles on it and when I used a battery on it it hits hard and spins free but when I put the start back in it just clicks so I tried to jump the starter with the key in the "on" position like I would be pop starting it and it will not turn over it just clicks I dont understand what the hell is going on. it like a short in the ignition system from the key to the solenoid there has to be a short or broken wire or something its really got me mind fcuked real good.....
a quick way to verify that the starter works on car is to run a fused wire from 12volts to the small single wire. This will also tell you if you have a wiring related issue in the ignition circuit. If the starter cranks this way you either have a bad switch or wiring between A and B.
This is a very good tip. This is the easiest way to rule out battery/starter and begin your focus on wiring if it works.neverlift wrote:a quick way to verify that the starter works on car is to run a fused wire from 12volts to the small single wire. This will also tell you if you have a wiring related issue in the ignition circuit. If the starter cranks this way you either have a bad switch or wiring between A and B.
Make sure your ignition is in the ON position though if you're ok with it starting during this test.
- 500hpKA240sx
ok kool I will do that its been in the teens here and I fcukin hate the cold so hopfully I will get to do something tomorrow after work. thanks for the help and ill post up what the problem was when/if I track it down.
clutch cancel switch on clutch pedal would be the first place i would look. second i would check the big white wire with a black stripe going to the ignition switch for bad connections i.e. alarm system, turbo timer, etc. or stupid ignition relay(starter relay)
N/A
- Drift Racer
Hi 500hpKA240sx, did you ever got to solve the problem?
I´m having the same problem on my KA24ET, some times starts without any issues, but when it starts, i noticed, it sounds like its struggling... and some other times, nothing, just the click when i turn the key! I have checked the battery and its good and strong, i haven´t tested anything else because the car has been satrting fine for the last 4 days!
Thanks
Thanks
- 500hpKA240sx
Ended up being the ground wire on the battery... Took it off and split the coating and the wire inside fell apart just old. Replace it and it will prolly be fine
- Drift Racer
Glad you found the solution for you
I forgot to say, i relocated my battery to the trunk, used brand new and thicker cables!
The most common cause for starter "click" issues comes down to voltage. The next biggest one is a solenoid problem. I've had a brand new (albeit remanned) alternator from an auto parts chain store. The component that makes the gear "leap" forward is good, but the component that is supposed to say "Okay, we're good to start spinning now", aka the brushes, are bad. This is why whacking the solenoid can help free this condition, but is never a permanent solution.
This is a very handy method to check if you have a voltage problem and it helps you pinpoint the problem wire(s). Voltage drop shouldn't be more than about ~0.5V when cranking. Everyone needs a multimeter!
http://youtu.be/ry68G0C2Fyc
Work smarter, not harder.
- Drift Racer
I tested the battery voltage before a took it out the garage 5 days ago!
The car was sitting on the garage for about 3 weeks, battery disconnected, so i tested it and read 12.5v, then conected the cables and started the engine, started at the second turn of the key, and with it running it read 13.9v!?
What do you think about this numbers??
Thanks
Thanks
- 500hpKA240sx
Everything's working fine your alt is charging at a level it should be it should never be over 14-14.5...only time you should have an over driven alt pulley to be charging at that level is if your pushing 3 big comp amps and your drawing power faster than your alt can charge. So back to the problem... Did you do a continuity test on the ground wires the one going from the neg. Battery terminal to the frame?
- Drift Racer
I haven´t tested the continuity, i´ll have to do that, what numbers should i see on the multimeter?
Thank you
Thank you
- 500hpKA240sx
you wont see any numbers. you go to one end and put either prong to the wire and then go to the terminal and put the other prong on it and the meter "depending on what one you have" it will either light up or beep. typically it will make a constant beep. but even if it does beep it doesnt mean the wire is necessarily good on the inside. what would be an easy test is to take another wire "copper would be best" and run it from the neg terminal to the strut tower bolt and just see if that stops the no start. like airman said also it could be the starter solenoid not wanting to thrust the gear on to the fly wheel. what you can do is have someone hold the multimeter on the solenoid post one side should be hot and the other side should be nothing thats where starting it comes into play, once your key is in the start position "all the way forward" it completes the circuit allowing power to pass through. make sure the multimeter is on DC and while someone is holding the black/neg to a ground and the red/pwr to the NON hot side of the solenoid go hit your key and when the car starts/turns over you should see 12v and as soon as you let go of the key it will go away. if you encounter the "click" and your not getting power to the solenoid then you have a bad wire some where, if you get the "click" and it spikes to 12v id say your start solenoid is bad.
- Drift Racer
Ok, so i just tested the continuity on the negative/ground wire and it´s ok, as far as the multimeter says, gives a constant beep!
About testing the solenoid, and to be honest, i didn´t understand your explanation Sorry
Can i test it without removing it from the car? I can see a bolted cable that looks like its on the solenoid, i think it´s the ground cable!
Thanks for all the help you have been giving me
- 500hpKA240sx
Shoot me a text or call and I can explain it better. 636 667 7756 names Kyle
- Drift Racer
Ok, so i tested the solenoid, from what i was able to see, the solenoid has 2 screw type pins, one is for the battery cable and the other has a cable that goes to the starter, i measured them both, and with the engine off, the battery cable pin reads 12.7V and when its started, drops to 9.0V and goes up to 13.4V!
The other pin (for the starter) reads 0.0V, when the key is turned to start the engine, and the engine starts, it goes up to arround 9.0V and back to 0.0V, and when it does not start, happened once, i get NO voltage on the multimeter!
What do you think??
Thanks
What do you think??
Thanks
- 500hpKA240sx
So hard to diagnose electrical through a forum are you getting signal from your key to the solenoid?....its sounds like the solenoid is bad to me.
- Drift Racer
I understand you, it´s very hard
Can you tell me how can i test the signal from key to solenoid? If i read you post correctely, i should be getting a 12V peak on start up (on the solenoid to starter pin), and not 9V, right?
Thanks for the help
Thanks for the help
- 500hpKA240sx
I'm at work right now ill check when I get home ill make a video and post it. Not sure on the 9v part.
- Drift Racer
Thanks man you´r the best
- 500hpKA240sx
now in the vid when its spiking to like 10.5v or so that's passing power from the hot side to the starter side. If it spikes and is clicking or not letting power pass through at all when it clicks the solenoid is prolly shot...
- Drift Racer
On my test, i didn´t conected the black probe on my battery, because it´s on the trunk, i used the suspension structure!
I tested like on the video, and on the solenoids battery pin (Hot side) i get 12.7V, on the other pin (Non hot side), 0.0V!
When i turn on the engine, i get a spiking to about 9.0V on the Non hot side!
I´m not sure if i made the readings correctly, here´s a pic of my multimeter,
i made my readings in volts, upper left side, next to the off position, black probe on the "COM" socket and the red one on the "V" socket, right one!
Thanks
Thanks
- 500hpKA240sx
Its passing connection like it should maybe a little low so I'm still leaning towards the solenoid. And I just used the neg battery terminal as my ground b/c I could stick it there and hold my camera I need some alligator clips but non the less your doing it fine a chassis ground is still a ground.
- Drift Racer
Ok, thanks for your video and help, tomorrow i´ll do some more readings, and i will probably wait until the engine gives me another click/no start situation, so i can check the numers!
I will remove the starter/solenoid from the engine and take it to a shop, to fix it!
I was wondering if this could be a ignition switch problem or the switch under the clutch pedal going bad or even the starter relay?
I might be able to check this parts as well!
Thank you
Thank you
- 500hpKA240sx
It wont be your clutch shut off switch put your car in neutral and don't push the clutch in and then turn the key it won't click. If it were bad it would do the same thing. The clicking your hearing is the solenoid trying to engage the starter. There are two screws in the solenoid from the opposite side of the terminal post, take them off and pull the solenoid out. It can be tricky to put back on sometimes but nothing to hard. Pull the plunger out and the spring behind it and use some emery cloth on the plunger and the inside of the solenoid with some wd40 or something similar and clean it all up and put it back on it prolly take care of your problem
- Drift Racer
Thanks 500hpKA240sx, i tried starting the engine without pressing the clutch, and no click then i pressed the clutch, turned the key and started right away, so the switch is working
I´ll try pulling the starter out and do the fix you described and see if it solves the problem i´ll let you know how it works out
Thanks
Thanks
- Drift Racer
Hi there, pulling this from the dead
So i took the starter to a repair shop, the guy tested it, it was working fine, he opened it and cleaned everything, i installed it back in the engine and it started fine for a couple of days, then, no start again, like i have the battery on the trunk, i´m going to check the ground, add a ground from the engine to the frame and replace the ground wire from the battery to the trunk (i´m using the stock cable)! I´m also thinking on testing the interlock relay!
