KA-t and Ac?
KA-t and Ac?
I've searched but my research isn't definitive. Which setup is easier to keep Ac and power steering in stock location on a 95 with KA24de? T3/4 top mount or t28 bottom mount? Also any specific manifolds I should look for to maintain these features? Ease of installation? Etc?
Re: KA-t and Ac?
I have ac and PS and am using a t3 top mount log manifold.
Re: KA-t and Ac?
Which log manifold?
Re: KA-t and Ac?
ebay mani
Re: KA-t and Ac?
I have 3 ebay manifolds early tubular, and two cast versions one on 2cyl the other on 2/3cyl all allow air and ps.
Re: KA-t and Ac?
Because I didn't carefully plan my oil return bung, it was in the way of the corner of the a/c bracket. I grinded the bracket and the a/c compressor to make it work thus only having 3 of 4 bolts securing the compressor. They're pretty hefty brackets and bolts so I don't foresee any issues on my end...
For my P/S I think I just moved the resevoir to another bolt that was already in the fender... I don't remember any issues.
This is with a JGS log manifold
KA-T / 50 trim / JGS manifold / DW550cc / Z32 maf / Q-Garage tune / 12psi
Philippians 4:6 Don’t worry about anything; instead, pray about everything. Tell God what you need, and thank him for all he has done.
Re: KA-t and Ac?
I've seen a few set-ups still with A/C. Might be a bit more tricky to do then if it wasn't there but it can be done.
Don't mean to thread jack but I can't post questions... for those who are running ebay top mounts, what is the quality like? Will I burn through? I remember my brothers old 1g talon had a ebay turbo mani and he burned pin holes through it twice... thanks for any info.
Re: KA-t and Ac?
The OBX T3 seemed decent but still cracked (with header heat wrap)DZTireSlayer wrote:I've seen a few set-ups still with A/C. Might be a bit more tricky to do then if it wasn't there but it can be done.
viewtopic.php?f=12&t=40453
http://www.ebay.com/itm/OBX-Turbo-Manif ... 2577wt_924
This is cast iron so it shouldn't crack, but needs some porting to match the head flange to the head. Heck for the price you could take it somewhere to get ported/ have them build you a downpipe and still come out pretty good.
http://www.ebay.com/itm/1989-1990-1991- ... 302wt_1161
Any other cheap ebay manifolds are proven garbage..
Sorry for adding to the threadjack, but my useful info was already added for the OP
Re: KA-t and Ac?
do bottom mount t28 setups interfere w/ ac/ps? my plan is to run an S15 dbb turbo and retain ac/ps.
Re: KA-t and Ac?
gtrpryde wrote:The OBX T3 seemed decent but still cracked (with header heat wrap)DZTireSlayer wrote:I've seen a few set-ups still with A/C. Might be a bit more tricky to do then if it wasn't there but it can be done.
Thanks for the info man! Much appreciated
