looking for links/references/pictures on what others have done for making diy exhaust silencers.
have a 4" tip -> 3" piping that I am trying to make a silencer for, not sure how to go about it. figured someone here would have made one before. Will just be searching for ideas in the meantime
diy exhaust silencers?
- beercandrifter
Re: diy exhaust silencers?
I've used a lawnmower muffler before(3") after some cutting and drilling it was alright.. Was not worth the effort a resonator would have done more and been less work.
- beercandrifter
neverlift wrote:I've used a lawnmower muffler before(3") after some cutting and drilling it was alright.. Was not worth the effort a resonator would have done more and been less work.
debating between some steel wool with a drain cover or dual pipes with 2 1/4 pipes instead of the single 3".
maybe stainless steel wool I would not trust regular steel wool for more than 6 moths daily here in humid florida. Loooooooose fiberglass packing will kill a good amount of noise.
- beercandrifter
didnt even think about the wool rusting, thanks for reminding me. I really want to just pack it for now so I can fire up the car. everything seems to be more noisy until you get idle sorted out on the tune
i found these nifty butterfly valves you can put inline with your exhaust that let you open/close them to dampen some of the noise. seems to be no more than a throttlebody with a cable on it to me
http://www.apexi-usa.com/store/exhaust/ ... alves.html
I added two resonators from Vibrant performance (aka Verocious Motorsports) to my exhaust and they made a huge difference. I added one of these where the cat would go: http://www.verociousmotorsports.com/Sho ... -Resonator
And I put one of these on a straight section that runs next to the driveshaft: http://www.verociousmotorsports.com/Sho ... tor-18-OAL
- beercandrifter
right now the 3" exhaust has 2 mufflers and a 18" resonator. was hoping for a cheap solution, otherwise it just makes sense to replace the whole exhaust
thanks for the input guys
i took a 10$ ebay silencer and chopped off the tube so i was left with just the cone insert.
took the cone (right where i just cut off the tube) to a sander to open up the diameter as i think it was all of 1.5"
got a peice of 2.5" pipe about 12" long.
swiss cheezed it. prob like 70 3/8th inch holes
welded em together.
looped a piece of mechanics wire off a hole on one end.
wrapped the tube in home insulation and used the mechanics wire to tie it all down.
some times we have muffled events and it works and even sounds great. it does create a fair amount of back pressure though despite all the holes and the fair sized diameter. my boost drops like 3 psi with it in.
welded em together.
