Im curious to the bosch 1000cc stainless steel injectors
Pros cons?
Anyone running these?
Injectors
Re: Injectors
I may be wrong, but I am under the impression that most Bosch/Siemens/ID injectors are all pretty much the same. Just different variety in impedance / etc.
Re: Injectors
I ran delphi 1000cc. Worked great. I am now on Bosch 1600cc. Idle control is a little hassle but other than that, work great.
Re: Injectors
Not to hijack, but what are your idle issues with them? Just rough I imagine?
Re: Injectors
Just need to run a bit richer around 13.5 afr at idle to have a smooth idle. Going below 1.5 ms causes the car to surge at 900 rpm. I don't like rich idle and try to be around 15.5 afr. I need to put my iacv to get a good idle. Idle is the least of my worries right now.
Re: Injectors
you guys know anything about the denso injectors? they are cheap and look crappy xD but still cheap
Re: Injectors
To OP, unless you power goals are past 400hp on E85 those 1000 Bosch ought to serve you well.
For Señor 240sxpt - I wouldn't say Denso has a bad rep. There are lots of shared / rebranded injectors out there. My "Fuel Injector Clinic" injectors are probably Bosch/Delphi/Siemens or something, so I feel like they will be okay. Most likely are modded to be as big as they are, but nevertheless we shall see how they do.
Re: Injectors
yup, i'll warn you guys if they suck xD
Re: Injectors
hey when you guys run bosch style injectors do you bore your intake manifold out to 14mm? is there a way of doing it without?
edit: was just shown a photo of some metal adaptors, about to try and turn some on the lathe, sorry to post off topic, i was stressin hard about this =)
