I was curious if anyone knew any of the specs on the stock s13 e-fan relay? curious what amperage it can handle
I am contemplating buying a set of newer altima fans and plan on wiring a relay to my megasquirt unit. It would be wonderful if i could use the stock relay until i replace the whole chassis harness.
rating of stock e-fan relay? altima fan q
- beercandrifter
Last edited by beercandrifter on Wed Jul 23, 2014 5:14 am, edited 1 time in total.
- Nomad
Re: rating of stock e-fan relay?
Stanza efans run 30amp fuses from the battery with a standard Nissan blue relay to switch them.
Therefore, I would assume the standard relay can comfortably handle at least 30amps, but probably a bit more knowing Nissan would build in a bit of a safety margin.
1995 D21 Navara Dual Cab
Socketed U12 ECU
Tuned ROM/NVSRAM
Socketed U12 ECU
Tuned ROM/NVSRAM
- beercandrifter
Re: rating of stock e-fan relay? altima fan q
so, has anyone here successfully run a set of late 90's altima fans off the stock efan relay? (hoping someone says yes, because a stand alone relay and harness costs half of what it would for me to just by an ezwiring chassis harness with a fan relay included.)
