low compression n/a??
need help i have been looking in several forums and cant find the answer. first off i will be using arias 8.8:1 comp pistons with eagle rods, arp hardware, felpro gaskets and its going to be bored .20 over and king bearings, top end is going to be pretty much stock im building for turbo but i want to break in the engine first so my question is can i run it on stock injectors and ECU n/a just for break in?
Re: low compression n/a??
yes, might not hurt to bump the base timing a few degrees.
sdbhfvasdjkaf
sdbhfvasdjkaf
so it wouldnt hurt the engine at all? I have heard it will run like crap but just want to be sure there wont be any issue running it stock
