Nissan discontinued ka24de oil pumps...? WTF
mewantkouki
Post by mewantkouki » Tue Oct 21, 2014 9:08 am
So it looks like Nissan isn't making oil pump / front cover assemblies for ka24de's anymore... What are the options? Anyone have a new oem s14 pump they want to sell?
hotbox240
Re: Nissan discontinued ka24de oil pumps...? WTF
Post by hotbox240 » Tue Oct 21, 2014 10:12 am
I just checked http://www.courtesyparts.com/ and your right. Weird , because I just ordered one last spring. You should still be able to get one off ebay.
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
Bubba
Post by Bubba » Wed Oct 22, 2014 11:37 pm
That is just ***** wrong....
I need a new oil pump for my fresh engine that is sitting at the machine shop.
My car is dead stock.... ish
http://mobileimports.freeforums.org
flip240
Post by flip240 » Thu Oct 23, 2014 8:28 pm
Both Rockauto and another website that typically carries OEM aftermarket uses DNJ. Might be worth e-mailing them to see where they are manufactured.
My setup: KA24DE-T
darrell
Post by darrell » Fri Oct 24, 2014 10:38 am
flip240 wrote:Both Rockauto and another website that typically carries OEM aftermarket uses DNJ. Might be worth e-mailing them to see where they are manufactured.
When I ordered one (DNJ) from Rockauto in February they sent me a used damaged remanufacture (still had gaskets on it).
Ended up sending it back for a refund and ordering from Courtesy Nissan.
They even managed to crack the pump gear during assembly.
Post by adamky » Fri Oct 24, 2014 4:56 pm
Well, this sucks. Dammit, Nissan, what the hell are you doing?
S14wayz
Post by S14wayz » Tue Oct 28, 2014 9:34 pm
thats retarded....I got my OEM pump off realstreetperformance awhile back, check them out and see if they have some left
My S14 Build Thread
viewtopic.php?f=40&t=59534
kxmike87
Post by kxmike87 » Thu Oct 30, 2014 3:59 pm
Mike
S14 Kouki Conversion
Fully built KA24DE
BC V3 Cams
SR20 clutch Backing it(the irony)
T3/To4e with dual ball bearing GT CHRA
Nistune at 14psi and rising
1000cc Injectors-Precision Turbo
Self_tuned :)
and more....
nissanfanatic
Post by nissanfanatic » Sun Nov 02, 2014 5:15 am
DNJ makes some of the worst replacement parts I have ever seen.
-Cory
2000 Honda S2000 [ GONE ]
2009 Honda Fit Sport [ OK ]
2002 BMW 325i Sedan [ OK ]
Use Linux...
ka240de
Post by ka240de » Sun Nov 02, 2014 8:53 am
time for an aftermarket oil pump guys. get a group buy from tomie or something.
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
nissanfanatic
Post by nissanfanatic » Sun Nov 02, 2014 8:56 am
I've never actually had one fail or "wear out". I think you can generally just clean/rebuild and be fine.
-Cory
Use Linux...
ka240de
Post by ka240de » Sun Nov 02, 2014 9:03 am
nissanfanatic wrote:I've never actually had one fail or "wear out". I think you can generally just clean/rebuild and be fine.
search hard on enjuku they were selling gears & relief valves for no more than 100$. i actually regret spending 400$on an oik pump from enjuku. nor did i need a water pump, probably coulda ran without a mishimoto thermostat too.. young and stupid.
Post by schmauster920 » Mon Nov 03, 2014 4:31 pm
If youve taken them apart after high mileage the steel gears wear into the aluminum cover, this creates a place for the pump to leak internally and loose pressure/efficiency. This takes 200k+ miles though.
This is also why the 'oil pump rebuild kits' are garbage. The gears are fine 90% of the time unless you had bad things in the motor, the timing cover is what wears
s13240
Post by s13240 » Wed Nov 05, 2014 12:02 pm
Well that's not cool at all. Has it come to the point already where we are rebuilding cars that the automaker will slowly no longer make any parts for. Its sad.
SoundEfx
Post by SoundEfx » Sat Nov 08, 2014 9:35 am
s13240 wrote:Well that's not cool at all. Has it come to the point already where we are rebuilding cars that the automaker will slowly no longer make any parts for. Its sad.
That isn't too bad considering that they no longer make the front bumper of a 2003 B15.
I hope that manufactures continue to make parts for these cars so that they can stay on the roads longer.
Notice I said manufactureS, because lord help us if only one manufacture supports us.... :(
Image << Yuh dun know!!
nisfinitikid093
Post by nisfinitikid093 » Sun Nov 09, 2014 10:00 pm
I can't believe that. I work at Nissan and I put a fresh OEM cover on my KA-T this year in April so I'm not sure when they decided to stop making them.
