Dual vs single maf?
Dual vs single maf?
Jst need a quick answer ...I have a 240 that originally came with a ka24 single cam but put a dual instead still has the original maf sensor..will the car have issues like run rich..etc
1990 240sx hatch N/A.
- street_240sx
Re: Dual vs single maf?
Ka24e mafs is same as sr20 which is different from the ka24de one
03 evo8 gsr: stroker 2.3
Oh thanks for the information...but I have one more question ..how can I distinguish between which maf it is? Because when I got the vehicle it came with a ka24de but before that it had an sr motor and it originally came stick with a single..don't know which one I have ..but also would having the wrong maf cause the car to run weird ? Like run rich
- street_240sx
I think the connectors differ. And part numbers
Wrong MAF will definitely cause the car to run strangely if the ECU is expecting a different MAF. The air flow/voltage output characteristics (I believe you can call this a VQ map?) are different from MAF to MAF.
Oh thanks. I've had my car forever it ran decent but ran rich and would backfire at times..blow the head gasket and jst ended up replacing full engine but been having issues since then..it was sitting in the back yard for so many years till it got the motor..got the same kind of motor a ka24de..not once did I every considered or thought it would be the maf because asuming it had the same motor as before..which was also a dual..bought a maf sensor for dual and will see if there is a change, I will keep you guys updated
Jst got an update.. Bought another maf.. Now car is running great..got some other stuff replace too..but I am certain the maf was causing all the issues to act the way it was
