Our Manzo manifold failed today after less than 1,000 miles. The pipe for the waste gate broke off (see pics). Our set up: the waste gate had a short down dump pipe and was exhausting to the ground near the firewall. For about half of the 1,000 miles this down pipe had no support, so I am guessing that the unsupported weight of the waste gate and pipe vibrated and caused the failure?
I am attempting to get a refund, but I have some questions:
1) Has this happened to anyone else? I did a quick search and couldn't find anything.
2) What manufactures do people recommend for a quality product.
3) Do people using a dump pipe like ours provide any significant support to avoid failures?
[URL=http://s1349.photobucket.com/user/ ... .jpg[/img][/url]
Why did Exhaust Manifold Fail?
- hotbox240
Re: Why did Exhaust Manifold Fail?
I had a Phat KA-T manifold crack on me years ago in a similar fashion. Having the wastegate recirculated back into the down pipe definitely gives it more support.
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
A lot of folks weld extra bracing and make use of flex sections to eliminate any excess stress on the manifold and avoid an event like this. A lower cost item will use thinner-walled pipe and may not be as thought-through when it comes to stress concentration and preparing for repetitive heating/cooling cycles - increasing the risk of cracks. Sorry to see this happen to you!
I have had this issue happen to me twice with cheap eBay manifolds. I welded them back up and braced. They never failed again.
Same exact thing happened to me also with my Ebay style manifold withing the first 1000 miles. I also re welded mine, braced it and it never cracked at that position again.
