oil lines/pressure.
modulation
oil lines/pressure.
Post by modulation »
I was running a tee straight off the block with line to turbo and oil pressure sender coming off of it. A BSPT and 1/4 NPT connector connecting the tee the the block. Oil pressure was always good etc..
This morning all I did was move the tee off the block with a -3an line. A -3an line also goes to the turbo. I am now seeing max oil psi of ~40-45 instead of like 60 before I moved the tee of the block. Is it because I'm using two -3an lines, and the line from the block to the tee needs to be bigger?
I thought it might because of added resistance since the pressure sender gets gnd though the hoses connected to the block, but when I measure resistance from the chassis to the sender I don't see any.
I triple/quadruple checked and I'm not leaking oil from any of the connections.
Re: oil lines/pressure.
Post by airman »
Interesting problem...one way to be sure your re-plumbing is causing the perceived pressure drop would be to go back to your old routing and see if it goes back to normal. I can't see why it should have affected anything though...
modulation
Bringing this back from the past, I finally got around to redoing lines. I now have the brass tee back on the engine block. Instead of having pressure sender right on the brass tee, I have a line running from the tee to the sender, and a separate line from the tee to the turbo. Oil pressure sender indicates oil pressure is back to where it was before I moved the tee off the block and then going to the turbo.
