npr piston set
npr piston set
Anyone have any experience with npr pistons for a low boost engine??? Found a set on eBay for $130
Re: npr piston set
I'm sure they are fine for a "stock replacement", but they won't provide the level of strength you would find in a set of forged (as opposed to cast) pistons.
I would treat them like stock pistons, which, depending on the tune can fail below 300hp. Enough detonation/knock will be a quick end to stock/OEM pistons.
Re: npr piston set
Thanks I wasn't thinking about them being anything better thans stock replacement...
