I tore the stock rubber coupler on my stock driveshaft (picture is in my build thread). My question is since I have a N/A 300zx differential do I need the driveshaft-shop DRIVESHAFT with or without ABS? My car did not come with factory ABS, nor does it have ABS.
Thanks!
http://www.enjukuracing.com/products/dr ... 20det.html
New Driveshaft
New Driveshaft
Cosmetic Head Gasket
Eagle Rods
Stock flywheel
Spec Stage 3+ Clutch
ARP'ed Everything
Clevite Bearings
SARD 850cc Injectors
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
