s14 Turbo hood clearance issues advice
what do you top mount guys do to clear the hood with bigger turbos?? any suggestions are welcome. i really dont wanna cut into hood or use hood spacers.
Re: s14 Turbo hood clearance issues advice
If you don't want to cut into the hood support or use head spacers, your only other option is to lower and/or tilt the engine. The KA already sits crooked, so I wouldn't try and tilt it any more. Xcessive makes lowering engine mounts that bring the motor down 3/4": https://xcessivemanufacturing.com/nissa ... -lmmb.html
You just have to be mindful that your oil pan may be the lowest point on your car after that. With stock pan, that may not be a huge issue. But with the Xcessive oil pan adapter and my ISIS SR sump, my pan is already very low. So, on my car, I cut my hood support for clearance.
