What's the right way to clean AEM Map sensor?
I have a can of electrical contact cleaner but don't wanna use it without knowing for sure. What do you guys do to clean your map sensors? I need to know for the connector side AND the air side. Thanks !
Re: What's the right way to clean AEM Map sensor?
I would call AEM and ask personally. They seem to be very fragile...my first one was defective out of the box.
Where in CT you from?
Pretty sure you cant clean them, its a small hole with a diaphragm. Make sure the tubing to it isn't plugged/kinked.
It might be helpful to list the details of the problem, maybe someone has come across it before.
Waterbury, and all is well with the sensor just tapped it on my finger with a towel and a little oil came out. Car is tuned and running greattuzzio wrote:I would call AEM and ask personally. They seem to be very fragile...my first one was defective out of the box.
