Turbo coolant lines
Turbo coolant lines
Postby s14nep » Wed Feb 15, 2017 3:24 pm
Anyone know what thread size the heater core fitting is on the block? I'm deleting the heater core and using the port to run my am lines to the turbo. I'm using the drain plug on the driver side of the block as a supply and the thread pitch on that is 1/4 bspt and I found -8 adapters for this. But now I'm stuck trying to find info on the heater core thread. Any info would be great.
s14nep
Re: Turbo coolant lines
Postby tuzzio » Fri Feb 24, 2017 10:25 am
At worst come to worst, just get a barbed to AN adapter fitting and run a short length of rubber line.
tuzzio
Postby s14nep » Tue Mar 21, 2017 8:41 am
Well i figured out the the thread pitch if anyone needs the info. The heater core hose end thread is 3/8" bspt not npts and the drain plug under the exhaust manifold is 1/4" bspt. Will post pics of my set up later.
s14nep
Postby Pegasus » Mon Nov 20, 2017 7:41 pm
You sure that’s what it is? I used an m16x1.5 fitting adapter and it threaded on for the heater core side.
Also do you have a part number on the fitting you used for under the manifold.
Pegasus
Postby Pegasus » Tue Jan 30, 2018 7:17 pm
welp since the op didnt respond, i bought a 1/4bspt fitting adapter and i will chime in to see if it works for the coolant tap under the exhaust manifold.
Pegasus
Postby calebbo » Thu Feb 08, 2018 11:14 am
Can you guys post pics of your set ups for the coolant hoses?
I am looking for the bolt underneath the intake manifold that everyone says they use.
Where do you guys feed and drain your coolant too?
calebbo
Postby calebbo » Thu Feb 15, 2018 10:48 am
Pegasus wrote:welp since the op didnt respond, i bought a 1/4bspt fitting adapter and i will chime in to see if it works for the coolant tap under the exhaust manifold.
Hey what were your results? I bought a 1/4BSPT to 1/4NPT fitting. Then I bought a 1/4 NPT to -6an fitting.
calebbo
Return to KA-T Tech. Advanced
Users browsing this forum: No registered users and 10 guests
