ECU PINOUT DATABASE
ECU PINOUT DATABASE
Postby Koukster » Fri Jun 16, 2006 3:12 pm
I would like for a moderator to place this as a STICKY or in the TECINFO section. This is very helpful information. This site has the ecu pinouts for many different cars, as well as OBDII, OBD1 and pre OBD 240sx's.
http://www.plxdevices.com/ecudatabase.htm
Koukster
Postby MaxRPM » Fri Jun 16, 2006 6:52 pm
Nice find...this is great for all car lover....
MaxRPM
Postby Koukster » Sat Jun 17, 2006 2:34 pm
Thanks, hopefully this will help someone someday.
Koukster
Postby Ali 556 » Sat Aug 26, 2006 3:47 pm
thanks man greatttttttttttttt :wink:
All you say is words.........words can't hurt me.
Ali 556
Postby dopeassjackson » Tue Aug 29, 2006 8:12 pm
to bad theres not one for any KAs.
rebuilt KA24E, port and polish, secondaries removed, stage3 clutch, fidanza flywheel, JGS MM, 3inch cat back with high flow cat, cherry bomb vortex muffler, B&M short shifter,ST sways,nismo brase
KA24ET RB20 turbo, 460cc
dopeassjackson
Postby Koukster » Tue Aug 29, 2006 8:32 pm
ummm.....you might want to take a second look. That site has both obd I and OBDII ka ecu model pinouts.
Koukster
Postby Greaser » Thu Oct 19, 2006 4:56 pm
you should check out aem's forum. any car/motor they make a box for has detailed pinouts.
Greaser
Master of Knowledge
Postby Koukster » Fri Oct 20, 2006 8:44 am
could you post a link for all of us to have quick and easy access????
Koukster
Postby slipnfall » Wed Dec 27, 2006 10:36 am
The KA pinouts are incomplete. The following are the three connections for the CONSULT I/II interface:
ECU Pin7 - Grb/Blk - RX
ECU Pin14 - Grn/Why - CLK
ECU Pin15 - Grn - TX
Factory service manual FTW. :wink:
'92 MS13 - getting there...
slipnfall
Postby slipnfall » Wed Dec 27, 2006 9:40 pm
For reference, here are the extras. Taken from 89-94 USDM 240sx FSM. No guarantees on accuracy. Also note that the ECU connector shown on the above website is pictured from the harness side, or looking into the ECU.
!EN is active LOW output: when this pin is low(ground) the device will then enable/turn on
!IN is active LOW input: when low(ground) this signifies the device is active.
1: power transistor NPN base output
3: to dropping resistor to NPN collector
8: EGR Temp Sensor
9: condensor fan !EN
11: AC condensor !EN
12: A/T
22/30: CPS Signal 1
24: CEL !EN
25: Swirl Control Valve sol !EN
27: Knock sensor input
28: A/T
31/40: CPS Signal 2
33: 5th gear !IN
34: Start signal in (12V)
35: Neutral !IN
37: TPS 5V
41: Thermo Amp
42: 4th gear !IN
43: Power steering pressure !IN
44: Rear window defog !IN
45: Ambient Switch / IACV-FICD !IN
102: PAIR sol !EN
104: Fuel pump relay !EN
105: EGR sol !EN
113: IACV-AAC PWM signal
slipnfall
Postby Koukster » Thu Feb 15, 2007 9:13 pm
thanks for your post
Koukster
Postby sG Ghost » Fri May 30, 2008 2:25 pm
Awesome. This Helped!
sG Ghost
Postby UNISA JECS » Tue Jan 13, 2009 9:50 am
This one should be pretty accurate I went threw the 91 wiring diagram, I did find a few in inaccuracys from other pinouts, cant remember which ones but this is pretty much straight out the 91 FSM.
Rep/Feedbacks
http://www.zilvia.net/f/showthread.php?t=134726
Z32 E-Brake/Parking Brake Heatshield Assemblys!!!
http://www.zilvia.net/f/sale-items/1667 ... plete.html
Rep/Feedbacks
UNISA JECS
Postby 13waynegarcia » Sat Aug 21, 2010 3:41 pm
that link doesn't work anymore
13waynegarcia
Postby z240xs » Fri Sep 17, 2010 4:20 pm
how about an S14 lay out
boosting it! solving it!
z240xs
Postby adamky » Fri Sep 17, 2010 5:50 pm
Totally forgot I had these.
S13 DOHC (1991-94)
1995
1996
1997-98
Postby z240xs » Fri Sep 17, 2010 7:40 pm
ya that guy just got a medal haha
z240xs
Postby Kfred » Mon Nov 08, 2010 5:12 pm
Woops posted in wrong thread.
Kfred -10 points
RIP Nate(480sx)...
Kfred
Postby OnTheChip » Sat Jan 15, 2011 8:15 am
13waynegarcia wrote:that link doesn't work anymore
The new link is here:
http://www.plxdevices.com/support/ecupinoutdb.html
Cheers,
Dave
OnTheChip
Postby je_decoy » Tue Aug 30, 2011 2:00 pm
chip your a saint :bowdown: :angel:
je_decoy
Postby Walperstyle » Wed Nov 16, 2011 10:56 pm
would be nice for the admin of this site to host the pictures also on the site server so we can never loose them.
Postby 240s-ex » Tue Dec 18, 2012 6:40 pm
the links arent working for me
240s-ex
Return to KA-T Tech. Advanced
Users browsing this forum: No registered users and 60 guests
