Ok, after letting the motor sit overnight to cool down, i started it back up today.
It idle'd fine and smooth for about 2-3 mintues. Then the mis-fire starts up. It will mis-fire every couple of seconds and then after a while, one large mis-fire will knock the idle off wack and make the motor jump up and down from 500-1000 rpm until it drops low enough to stall out..
And it will do this all day long...
I can play with the gas pedal and sometimes it will smooth it out, sometimes is doesnt work and it just stalls out anyway...
Please tell me how this is OPEN BOV related...?? I know the symptons on open bov and and in the process of recirculating that back thru, but this mis-fire and irratic idle is somthing different...
Motor mis-fire after cold start up
- rn240sx
www.shopboldimpressions.com
06 Suzuki Boulevard S40
/\ all still current 8.30.20
- Greaser
- Master of Knowledge
Re: Motor mis-fire after cold start up
rn240sx wrote:Ok, after letting the motor sit overnight to cool down, i started it back up today.
cover up the bov with some duct tape and see if the problem continues. that will be the quick way to find out. also bad plugs will cause a misfire. I just put in a motor in my 89 and it ran fine until i revved it. put new plugs in and its all good.
did you remove your butterfly's in the intake mani?
- KA-T.org Featured Ride
Defiantly check the BOV for leaks. I just went through this yesterday with my car. Also check the vacuum like that runs from the intake to under the throttle body. Mine was slightly kinked and causing low and erratic idle.
________
Think mill
________
Think mill
- rn240sx
The ONLY vacuum lines i have on my manifold are the Brake booster, Fuel pressure regulator, BOV feed and my boost gauge feed. Thats it..!!
My recirculation adaptor for my bov will arrive here tomorrow but i dont see how that will cause backfire on idle, NOR make my idle jump between 400-1000 rpm..
My spark plugs are brand new and i used the plug wires from my spare ka motor sitting in the garage that was IN USE just under 2 months ago..
what heat range are those spark plugs? I know what you're talking about. The idle is so horrible you can't even time your motor. Try to idle the motor up to 900-1000 RPMs. Do this by using the IACV screw. Remember, that you must put the engine in the idle adjust mode first before adjusting the IACV. You must read you manual page EC-25 in the S14 manual. If the engine doesn't respond then there is a problem with that device.
In my honest opinion however I believe this is a spark misfire problem. I had it and I was able to improve my idle but it never was perfect. I had to get an ignition box to make it like stock again. Our stock ignition isn't as good as the SRs in my opinion. There for we have to up grade our ignition system to compensate for the larger injectors. There will be some S14's that might be able to handle the 50lbs injector upgrade because ignition system is working better than ours. My cure was the stock ignition can't get the job done for this size injector. Upgrade to an MSD box.
