The Ultimate 240SX Bible Volume 1
sstomek
Post by sstomek » Fri Jul 28, 2006 8:37 am
Alright well there is a lot of useful information out there on the internet. Unfortunately a lot of it is scattered all over the place. This is my attempt to try and bring everything to one place. I have separated them into categories to the best of my ability in the time i have heh which is not a lot. Well here it is the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info...
Electronics/ECU
ECU pinout diagrams.
REWIRING YOUR IGNITION COIL
Distributor Timing
Removing speed limiter on 93 KA24DET
DIY Ignition Mods for Better Spark
Sr20det Ecu Fault Codes
SR20DET ECU wiring diagram.
FAQ: KA ECU # Glossory
A long tutorial for tuning nissan's ECUs
How-To: Chip Your ECU with Pictures (KA24E)
Desoldering tips
Battery Relocation
Engine/Engine Info
SETTING THE BASE TIMING ON THE DOHC PROPERLY
How to build a KA24DE
How to: S13 Oil pan removal
DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE
How-to: Build Your Own Oil Cooler
S13 Red Top Vs. S13 Black Top - The differences
DOHC Turbo For Dummies
240sx Engine Descriptions
240SX How To: Removing/Replacing your PS pump
DIY: ITB's for your KA24DE
Basics of engine management
SR20DET Installation Guide
1993 240sx Capacities and Specifications
HOW-TO: Fix Your Timing Chain Rattle
KA24e to KA24de swap - Step-by-step.
240sx (S14) HotShot header install
Does my 240sx have a bad O2 sensor?
240sx knock sensor replacement
How to do a compression test on your engine
RB25DET into S13 Installation
Engine Knock (Detonation) Sensor Replacement (KA24DE)
Transmission
How To: Convert from A/T to M/T
How to Swap Your Auto Transmission for a 5-speed
Changing transmission fluid / oil on s13
How to install paddle shift on an automatic 240SX
240sx Clutch and Flywheel Swap
S14 auto -> manual with pics
Clutch Swap
Fuel/Nitrous
REWIRING YOUR WALBRO 255 FUEL PUMP ON S14's
240sx: Installing a Walbro Fuel Pump
240sx: Replacing Your KA24DE Fuel Injectors
DIY: Installing an injector resistor box
Nitrous Oxide FAQ
Turbo
HOW TO NEVER OVERBOOST AGAIN
Bobby's DIY turbo oil feed/return lines install
Turbo rebuild DIY
Turbocharging your automatic-trans car
Suspension/Differential/Brakes
Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential
The Definitive 300ZX Brake Swap!
Advanced Suspension Definitions
Rear differential swaps for the 240sx
Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion
Rexbo's Guide To Brake Caliper Rebuilding
240sx curb weights
All you ever wanted to know about differentials
Upgrading to J30 Brakes
ABS Removal
Interior
Removing the S13 Door Panel Fabric
Low-budget seat modification for S13
Re-covering Your S13 Glove Box
DIY: Window regulator repair 5$
DIY: Dye That Ugly Carpet!!!!! W/pics
Water leaking into trunk (240sx fastback)
Camera Mount
Exterior
HOW TO: Repaint Headlight Housing (Black)
DIY: Replacing Your Rusted Hatch
240sx Conversions - An Introduction
Sleepy Eyes walkthru (VID)
240sx Vented Hood DIY
Rust removal, Fiberglassing, and Body Filler
DIY: Silvia Foglight Wiring
All-red S13 Taillights
Restoring your Nissan's paint
240sx power antenna repair
Article: General car cleaning/detailing tips
Factory Service Manuals/Diagrams
Factory Service Manuals (FSMs)
Your home for factory service manuals
Parts Lists / Diagrams / Setting Sheets
HowStuffWorks Articles
How Manual Transmissions Work
How Differentials Work
How Turbochargers Work
What is the difference between a turbocharger and a supercharger on a car's engine?
How Car Engines Work
How Clutches Work
How Car Computers Work
How Fuel Injection Systems Work
How Car Suspensions Work
How Anti-Lock Brakes Work
How Master Cylinders and Combination Valves Work
What does it mean when a car has dual overhead cams?
How Camshafts Work
Now obviously people out there will think that there are some links missing to this bible and that is obviously true. That is where you guys come in. If you think that there is a useful link that should be in here the PLEASE post it and I will add to it. The bigger this thing is the better.
Oh and to some of the sites you have to be a registered user (and some you even have to have a certain amount of posts like night-stalkers) before you can view the material. I wish that this wasn't the case because information should be readily available but I guess I see where they are coming from.
Well thanks for looking
-Tomek
Al_s14
Post by Al_s14 » Fri Jul 28, 2006 9:14 am
holy **** dude, awesome job! now i know where all nobbs will be linked to from now on whenever they got a question :lol:
96s14
Post by 96s14 » Fri Jul 28, 2006 9:49 am
A mod should without a doubt sticky this. This is amazing. Awesome jobs and thanks.
7 psi: 251.0whp and 265.6wtq
9.25 psi: 287.3whp and 315.5wtq
12 psi: CONFIDENTIAL.
MaxRPM
Post by MaxRPM » Fri Jul 28, 2006 10:42 am
If all noob read this....they won't have to ask the same question 5 millions time...LOL
GREAT JOBS
shayan
Post by shayan » Fri Jul 28, 2006 10:44 am
this should be sticky
Skeeg
Post by Skeeg » Fri Jul 28, 2006 1:25 pm
great post. +1 on sticky 8)
s14det
Post by s14det » Fri Jul 28, 2006 1:26 pm
The funny thing is that sstomek is a noob. He only has 10 post.
I wish all Noobs had your knowledge, Awesome job man :D
monooxide
Post by monooxide » Fri Jul 28, 2006 4:17 pm
OK...define the word noob...In my definition a person could have 700+ posts and still be a noob. That guy with the Orange 240Z in his Signature...yea he def. is not a noob he knows his ****.
*Whistles*
1993 Coupe S14 SR w/ Bolt Ons and 1 Bar
286WTQ @ 3200 RPM
Biggamehitt
Post by Biggamehitt » Fri Jul 28, 2006 4:28 pm
nice , great for diy guys like me
lov2xlr8
Post by lov2xlr8 » Fri Jul 28, 2006 4:39 pm
holy ****, your my best friend :oops:
thanks for this i just reviewed it and already answered 3 of the many questions i have :lol:
PS: 1+ sticky!
shayrgob
Post by shayrgob » Fri Jul 28, 2006 5:03 pm
awesome! It would be nice if all this info could be on a site or something.
nismohardbody
Post by nismohardbody » Fri Jul 28, 2006 5:07 pm
the problem with noobs (including myself) is that they look through the topic titles and after looking though only a few pages in one forum, get bored and say f*** this, and post away. some dont even look at the stickys
1993 hardbody currently ka24e, 5spd, basically stock
ka24et buildup and swap coming this summer
www.nissancustoms.com
mach5camaroSS
Post by mach5camaroSS » Fri Jul 28, 2006 6:17 pm
sticky this thing up right now
90 HB KA24DET project
Best 1/4mile so far 12.56@114
My Cardomain:
http://www.cardomain.com/id/90_240SX_KA24DET
jpadilla12
Post by jpadilla12 » Fri Jul 28, 2006 6:28 pm
Finally someone had the time and was nice enough to do a full list. :D I sure a lot of people will need this big time. Good Job!!!!
sstomek
Post by sstomek » Fri Jul 28, 2006 7:09 pm
hahahaha, thanks alot guys. yea it took me a while but I got it done and i think it will be quite useful. Not only for the n00bs. while i was browsing i learned a few things of my own also...like a paddleshift 240, never knew that exsisted let alone a guide to doing it.
Heh yea im a n00b to the site, signed up cause im going ka-t all the way baby! Thought I'd start early with a sticky(maybe :):)) Heh, again thanks for the support.
-Tomek
sethstyle16
Post by sethstyle16 » Fri Jul 28, 2006 9:53 pm
superb
eDmSiL80
Post by eDmSiL80 » Fri Jul 28, 2006 9:55 pm
amen for this :P
Trippen
Post by Trippen » Sat Jul 29, 2006 9:57 am
Great Post .......................And the paddle shifter...Hummmm Maybe the new rims can wait a bit........
Trippen-
-Boost is like a bad habit the more you do it the more you want it.-
89 240sx se Hatch-NA RS*R race springs w/AGX's
92 240sx se Convertible-(Wifes Car) NA , Tanabe Coilovers..
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite. 275.5 tq 246hp @14psi
southjrz240
KA-T.org Featured Ride
Post by southjrz240 » Sat Jul 29, 2006 11:29 am
niceeee
http://www.ka-t.org/cain.htm
91 Hatch KA-T with the help of TURBO240
Gonad
Post by Gonad » Sat Jul 29, 2006 1:23 pm
I have some articles I've written myself you may find usefull :)
http://www.my240.com/index.php?parent=Articles
Gautam
Post by BigLoukaT » Sat Jul 29, 2006 2:22 pm
Just getting in this thread to subscribe for later reading - great work bringing it all together
lov2xlr8
Post by lov2xlr8 » Sat Jul 29, 2006 2:36 pm
here's something to add...
subie STi 4 piston brembos on 240sx:
http://www.zilvia.net/f/showthread.php?t=93748
:wink:
S13FX
Post by S13FX » Sat Jul 29, 2006 7:06 pm
Hey SSTomek is not a noob his a great guy and knows his **** in RL. Only reason he has so little post is cause he asks me for all the INFO LOL :-p hehe I thought Id be funny lol
sstomek
Post by sstomek » Sun Jul 30, 2006 10:32 am
^haha yea but its true, oh and me and s13fx are gonna open up a custom tune shop for your ka24d and ka24de ecu's. :)
-Tomek
sstomek
Post by sstomek » Sun Jul 30, 2006 6:00 pm
Gonad wrote:I have some articles I've written myself you may find usefull :)
haha nice, there are some great articles in there. I added half of them and will add the other half later. Dont have too much time. The problem is if I edit it here i have to edit it on the other forums i posted this on and it takes up some time. Thanks again for the articles.
lov2xlr8 wrote:here's something to add...
:wink:
Thanks also, gonna add the link with the rest of Gonads when i get the chance to. And i think you just showed me one more forum that i forgot about it terms of posting the bible up there...dang more screweing around with the html
turbonola
Post by turbonola » Sun Jul 30, 2006 10:29 pm
yo, +377,991 for stickness
11.65@118 1.64 60ft
babowc
Post by babowc » Sun Jul 30, 2006 11:42 pm
yayy my article is up on his DIY list :D
looking good you're putting it to good use!
p00t wrote:. A turbo is basically changing the size of your motor depending on your mood 8)
sstomek
Post by sstomek » Fri Aug 04, 2006 11:00 am
more updates coming soon...slow and dteady. i still have to add the rest of those links...hehe im in need of some time
-Tomek
Rick
KA-T.org Co-Owner
KA-T.org Co-Owner
Post by Rick » Fri Aug 04, 2006 5:43 pm
STUCK
sstomek
Post by sstomek » Sat Aug 05, 2006 10:55 am
Rick wrote:STUCK
yay :) thanks
