How to run CBR coils
Postby BRAD D » Mon Jun 04, 2007 9:01 pm
Still running strong but I have only had it running at my house, Just mount it in the car and I also hear some coils could kill it, not the CBR' but some from a yamaha??
BRAD D
KA-T.org Featured Ride
Postby wildbama37 » Tue Jun 05, 2007 7:24 am
BRAD D wrote:Still running strong but I have only had it running at my house, Just mount it in the car and I also hear some coils could kill it, not the CBR' but some from a yamaha??
did you read that on the aempower forums? at least we've got nothin to worry about though with the CBRs. Hey, on those AEM EMS settings that you posted, how did you figure out what values went in those setting spots? Are those the same exact settings that I should use too or is that more tailored to YOUR specific setup? Although our setups are very similar..
98 240sx
06 Lamborghini Gallardo
02 Mitsubishi Montero Sport
99 Infiniti QX-4
07 Suzuki gsxr-600
wildbama37
Postby BRAD D » Tue Jun 05, 2007 9:12 am
You can copy them all... the ing sync will be off any ways.. but you need to set up the timing any way... and check for timing drift (mine did not drift.) Its ok for the timing to move while you rev it up but once you sit at any RPM it should stop in the spot you have it set to. mine moves retarted as you rev it, but is you sit at one rpm it sits in the right spot.
As for the info about the twin fire it was on another forum, the guy took it apart and said it looked like it was made my MSD... Dont know if thats good or bad ;)
BRAD D
Postby wildbama37 » Tue Jun 05, 2007 12:37 pm
so hey, where can we order these Denso plugs? I called the honda cycle shop here in town and they don't carry them sparkplugs.com a good site to order from?
98 240sx
99 Infiniti QX-4
07 Suzuki gsxr-600
wildbama37
Postby BRAD D » Thu Jun 07, 2007 2:02 pm
BRAD D
Postby wildbama37 » Fri Jun 08, 2007 11:47 am
Do we need to gap these down since we are running the TwinFire or are we good to leave them where they are at as far as the gap goes? I figured since we have a really strong ignition spark that we would be ok to just not gap them at all.
98 240sx
99 Infiniti QX-4
07 Suzuki gsxr-600
wildbama37
Postby BRAD D » Fri Jun 08, 2007 12:02 pm
I have them down to .025" They seem to idle fine.
BRAD D
Postby Rick » Mon Jun 18, 2007 11:30 am
AWESOME BRAD!
Stickied--
Rick
Rick
KA-T.org Co-Owner
KA-T.org Co-Owner
Postby BRAD D » Mon Jun 25, 2007 8:28 pm
Well its working pretty good, still doing some tuning just have a mild stumble under light load in the lower RPMs. looking to fix it but have not solved it yet.
BRAD D
Postby wildbama37 » Mon Jun 25, 2007 10:04 pm
BRAD D wrote:Well its working pretty good, still doing some tuning just have a mild stumble under light load in the lower RPMs. looking to fix it but have not solved it yet.
you're running the misd dis-4 now arent u?
98 240sx
99 Infiniti QX-4
07 Suzuki gsxr-600
wildbama37
Postby BRAD D » Tue Jun 26, 2007 8:00 am
Yes for now, I would like to go back to the AEM... this DIS-4 is hard to fit in my car (close to the stock ECU spot)
BRAD D
Postby smracing » Tue Jun 26, 2007 11:32 am
Did you use an ignitor, or switch the jumpers in the EMS?
smracing
Postby BRAD D » Tue Jun 26, 2007 12:04 pm
smracing wrote:Did you use an ignitor, or switch the jumpers in the EMS?
Just the jumpers on the EMS.. look at the 1st post on this page I updated it on how to use the dis-4... same plug as the twinfire.
BRAD D
Postby LT_Z » Thu Aug 30, 2007 6:08 pm
is there an advantage to running the LS1 coilovers vs CBR ? i like how the CBR "looks" completed. . . . just wondering if there is an advantage
LT_Z
Postby BRAD D » Thu Aug 30, 2007 9:26 pm
LT_Z wrote:is there an advantage to running the LS1 coilovers vs CBR ? i like how the CBR "looks" completed. . . . just wondering if there is an advantage
i dont know... the CBRs seem to be fine..... but the LS1 could be stronger.. they are bigger???
BRAD D
Postby R@mon » Mon Sep 03, 2007 7:23 pm
just got me some new coils. With these coils i can fire them directly from aem without the need for a ignition box. Ive already fried 2 aem twin fires, so im done with aems ignition products. plus the coils are pretty cheap.
R@mon
Postby Nissankat » Fri Dec 14, 2007 10:43 pm
Is the new version of the twin fire out yet? Anyone tried it?
Nissankat
Postby klattr1 » Mon Jul 14, 2008 8:17 am
kedbmx wrote:does anyone know the part number for the cbr coils? thanks in advance.
buy the AEM "pencil coils" (short versions) and then you can run standard style spark plugs (like NGK copper):
http://aempower.com/ViewCategory.aspx?CategoryID=123
klattr1
Postby knightkid » Wed Nov 05, 2008 12:54 am
jsut a thought.. might be kinda off topic but if were running a sr20det or dsm ecu, is this useable?
Stright lines are for fast cars, The curves are for fast drivers.....
knightkid
Postby vladt3 » Tue Oct 06, 2009 8:54 am
can using launch control with indepent coil??
vladt3
Postby Mark Washington » Thu Mar 04, 2010 2:51 am
I have a 02 yamaha and a couple extra engines. I just need to know the ohms from the Honda ones.
速い速い シルビア ターボターボ
Mark Washington
Postby Mark Washington » Thu May 27, 2010 6:49 pm
Denso 129700-4400, J0440.
CBR954RR has 1.2 ohms
My 02 R6 coils have .6-1.2 ohms and fit #R5671A-7
"If you are just looking for simple, ease of installing, the EDIS-x setup with the FORD or Chrysler coil pack is about as easy as it gets. As close to Plug and play as you are going to get, other than the configuration hurdles within EMS/MegaSquirt/MegaTune of course.
EDIS is Fords brand name for this particular D.I.S. ignition system
LSx coils have the igniters built in, (electronic circuitry in the coils). With EDIS, the EDIS module itself is the igniter that triggers the coils, and the EDIS/Chrysler coil packs are just coils, no other electronics in the coil pack. In short, the LS-x coils will NOT work with EDIS-x. As I understand, Z-ya was working on getting LS-x coils working with Mega Squirt, as I understand it, that is more complicated than using the EDIS ignition for the 6 cylinder. Might be less hassle for the 4 cylinder? (Hopefully Pete or Matt will chime in…)
The CBR coils with just a "+" and a "-" only sounds like they are just a coil, i.e. no electronics built in. Just need to verify they are compatible with EDIS electrically speaking and the EDIS dwell is adequate for the CBR coils"
Not to change the subject, but there are other coils with close ohms.
速い速い シルビア ターボターボ
Mark Washington
Postby Jmoore124 » Fri Dec 21, 2012 11:06 am
Sorry if this has been asked. Is there any way to have a setup similar to this with the stock/tuned ecu?
Jmoore124
Postby supakat » Fri Dec 21, 2012 11:38 am
Unless you run an SR ecu, you cannot run coil packs with KA ecu.
Postby nx2000det » Fri Dec 21, 2012 11:02 pm
Jmoore124 wrote:Sorry if this has been asked. Is there any way to have a setup similar to this with the stock/tuned ecu?
you may want to ask Nismotronic if they are working on it...
nx2000det
Previous
Return to KA-T Tech. Advanced
Users browsing this forum: No registered users and 50 guests
