Page 1 of 2
RB25 Trans behind a KA24DE
Posted: Fri Jul 13, 2007 7:10 am
by titec2
I ran across an RB25 transmission for a great price and was wondering how close it comes to bolting up to the KA. I know the output shaft is bigger but I don't think that will cause me any problems because I have a Drive shaft Shop drive shaft and I believe that they can make me a new yoke that will fit the RB trans. So how close does it come to bolting up?
Posted: Fri Jul 13, 2007 7:58 am
by nlzmo400r
ive never heard of anyone trying this. All of the RB guys I know use RB trannies and all of the KA guys use either KA/SR/VG trannies. You may have to just take measurements and see whats up
Posted: Fri Jul 13, 2007 9:27 am
by EviltoM
It wont bolt up, you will need to make a custom adapter, and a custom tranny mount too. From what I have read, the RB25 is the same tranny as the Z32 tranny but with different bellhousing. Can anyone confirm this?
Posted: Fri Jul 13, 2007 9:35 am
by titec2
I was talking to a local guy and he seems to remember that when he looked at this trans set-up that there were only two bolt holes that don't line up. One of the bolt holes in the trans bell housing he said is close enough that you can see 1/2 of the threaded hole in the block through it and the other will require a redrill. Can anyone confirm?
Posted: Fri Jul 13, 2007 1:50 pm
by LocAss24
kings_blend wrote:It wont bolt up, you will need to make a custom adapter, and a custom tranny mount too. From what I have read, the RB25 is the same tranny as the Z32 tranny but with different bellhousing. Can anyone confirm this?
Yup, basically the same tranny as the Z32.
Posted: Fri Jul 13, 2007 1:55 pm
by EviltoM
titec2 wrote:I was talking to a local guy and he seems to remember that when he looked at this trans set-up that there were only two bolt holes that don't line up. One of the bolt holes in the trans bell housing he said is close enough that you can see 1/2 of the threaded hole in the block through it and the other will require a redrill. Can anyone confirm?
If that is the case, we would be able to run modified RB26 trannys as well.I just picked up a z32 tranny form a buddy for $60 (best friends discount) and will be making my own adapter and mounts. Hopefully I can start early next month some time to be ready for the track events in september.
Posted: Fri Jul 13, 2007 2:05 pm
by titec2
Seems to me that if I can make this work without an adapter plate it would be a much better/easer way to get the durability of a z32/rb25 trans behind the ka. I talked with the guy form the driveshaft shop and he said that he can supply me with the correct yoke to work with the driveshaft shop drive shaft I already have and fit the rb output shaft. The guy with the rb transmission is going to bring it to my shop week after next and I will let you guys know what it is goint to take to make it work.
Posted: Fri Jul 13, 2007 2:11 pm
by EviltoM
Cool! cant wait for the results.
Posted: Sat Jul 14, 2007 6:25 am
by nlzmo400r
well if they're the same tranny are the bellhousings swappable? Saying using a z32 bellhousing with the rb25 trans? Can't wait to see the results of your experiment.
Posted: Sat Jul 14, 2007 7:12 am
by EviltoM
Ya they are, theres a guy on FA with an rb26 swap in his z32 and he used his original tranny with the RB25 bellhousing.
Posted: Sat Jul 14, 2007 9:24 am
by 05gsxr750
i heard of a guy useing a rb25 bell housing on his sr20det trans for his rb25 car when his trans went out and people local use sr bell on ka trans when there sr tran goes out. not too sure but it might work....there's a guy on ebay selling his rb25det powered coupe right now that has a bad trans in it and he has a sr trans to throw the 25 bell on to make it work.. so im leaning towards yes but i do not know.
Posted: Tue Jul 17, 2007 4:37 pm
by doggunracing
These transmissions are pretty different. VG and RB are similar but since Mazworx makes an adapter for the SR/KA to VG, I would say that there's no 'easy' bellhousing swap here.
Posted: Wed Jul 18, 2007 9:15 am
by ZmasterB
05gsxr750 wrote:i heard of a guy useing a rb25 bell housing on his sr20det trans for his rb25 car when his trans went out and people local use sr bell on ka trans when there sr tran goes out. not too sure but it might work....there's a guy on ebay selling his rb25det powered coupe right now that has a bad trans in it and he has a sr trans to throw the 25 bell on to make it work.. so im leaning towards yes but i do not know.
That is not possible......RB25 trans are 30A's, same as a Z32, and SR trans are 71C (RB20, CA18, SR20, and KA are all 71C). A 30A bell will not fit on a 71C trans......they are VERY different. What you are saying would be possible if it were using an RB20 bellhousing.....
I'm the "local guy" BTW :) I have put an RB20 bellhousing on a KA block, the dowels line right up, and only 2 bolt holes need to be modified, one of them is extremely close & could be done with a die grinder in a few minutes.
The RB trans' are a little shorter overall than a KA trans, so I'm interested to see how this turns out also.....I think shifter location/driveshaft length may be a problem, but we are gonna find out.
Posted: Wed Jul 18, 2007 9:52 pm
by titec2
Just a small update... The guy what has the RB25 trans also has a Mckinney drive shaft and trans mount as well. He is scheduled to bring the whole set-up to me on the 29th of this month. I am very excited to see where all of the pieces fall. If i could impose on ZmasterB; i would like to have one of his many ka24de transmissions on hand for comparison. What do you think ZmasterB?
Posted: Thu Jul 19, 2007 5:19 am
by EviltoM
Isnt the RB20 bellhousing compatible with the RB25/Z32 tranny then? And the McKinney driveshaft and mount are probably for the BR26 swap into an s13 or s14. Hmmm we might have all the parts readily available, we just have to put the pieces of the puzzle together.
Posted: Thu Jul 19, 2007 5:56 am
by titec2
That is what I am hoping. :D
Posted: Thu Jul 19, 2007 6:15 am
by ZmasterB
titec2 wrote: If i could impose on ZmasterB; i would like to have one of his many ka24de transmissions on hand for comparison. What do you think ZmasterB?
Yea I think we can rustle one up LOL.
I had forgotten, I have an RB20 trans that is very dead.....but it could be used for measurement purposes, it has the same tailshaft/overall length as the 25 trans.
Posted: Thu Jul 19, 2007 6:30 am
by ZmasterB
kings_blend wrote:Isnt the RB20 bellhousing compatible with the RB25/Z32 tranny then? And the McKinney driveshaft and mount are probably for the BR26 swap into an s13 or s14. Hmmm we might have all the parts readily available, we just have to put the pieces of the puzzle together.
Thats what I'm saying, no, the RB25/Z32 trans are 30A's (big), and the RB20's are 71C's (small, same trans as a KA/CA/SR). The bellhousing from a RB20/CA/KA/SR wont fit onto a RB25/Z32 trans.
I have a friend who is working on getting all the AWD stuff from an RB26 to work on a KA......but we'll see how that goes. The trans fits, its that oil pan/front diff thats a toughie :lol:
Posted: Thu Jul 19, 2007 11:46 am
by EviltoM
Oh I see. I was just hoping it would be true. Oh well, I guess I'll continue with my plans to make a custom adapter plate.
Posted: Wed Jan 20, 2010 10:35 am
by Tad_07
ZmasterB wrote:Thats what I'm saying, no, the RB25/Z32 trans are 30A's (big), and the RB20's are 71C's (small, same trans as a KA/CA/SR). The bellhousing from a RB20/CA/KA/SR wont fit onto a RB25/Z32 trans.
+1
I have a rb20 swap & the bell housing is just about the only difference btwn the ka, rb, & sr tranny. There are a few internal differences but nothing to give one more strength than the other.
A rb25 or z32 tranny on the other hand are much better, nicoclub as some good info on them
Posted: Wed Jan 20, 2010 12:26 pm
by Alonso
Wtf are you doing?
Bored?
Posted: Wed Jan 20, 2010 1:36 pm
by Dik_fitswell
Maybe swap the Ka bell housing on the rb trans. My friend has basically the same thing but reversed, rb bell housing on a ka trans.
Posted: Sun Sep 12, 2010 11:11 pm
by mo_hish
titec2 wrote:Seems to me that if I can make this work without an adapter plate it would be a much better/easer way to get the durability of a z32/rb25 trans behind the ka. I talked with the guy form the driveshaft shop and he said that he can supply me with the correct yoke to work with the driveshaft shop drive shaft I already have and fit the rb output shaft. The guy with the rb transmission is going to bring it to my shop week after next and I will let you guys know what it is goint to take to make it work.
Whatever happened to the guy running the rb25? Did he stop by and shed light on this?
Posted: Mon Sep 13, 2010 2:33 pm
by crazys14
it works, it's been done here in san diego a few times now only 2 bolts dont align.
these trannys are very expensive however which makes the z32 really cheaper in the long run if you ever need to replace the trannys.
Posted: Mon Sep 13, 2010 4:57 pm
by mo_hish
They seem to be pretty pricey, but the bell housing can be had for like 250. Can't I just grab the rb25/26 bell housing and bolt that up to the z32/pathfinder tranny? I know I'd need a custom driveshaft and I can fab up the mount if need be, but does the shifter come through the regular shifter hole?
Posted: Mon Sep 13, 2010 5:11 pm
by mo_hish
Also, I was wondering why we can't just redrill the z32 bellhousing to fit the ka. I mean, were essentially opening up two bolt holes with the rb25/26 or just leaving them be, so why can't I just pick up a z32 tranny and redrill some holes to mate it up with the ka?
Is it that the z32 is shaped differently or something?
Posted: Mon Sep 13, 2010 6:39 pm
by Kfred
The z32 bell housing is not even close to matching the ka block. The rb transmissions line up you just have to wallow out two holes.
You can put the rb bell housing on the z32 tranny and bolt it up to a ka, but the shifter will be back pretty far like this. The rb shifter is similar to the ka, while the z32 is remote mount.
Posted: Mon Sep 13, 2010 8:01 pm
by mo_hish
http://zilvia.net/f/chat/270726-pics-z3 ... y-s13.html
The placement in those pictures doesnt seem that off, and that's with the adapter pushing it farther. Is the bellhousing going to push it farther back than that?
The comparison pics of the rb25 vs z32 bellhousings here makes it seem like the difference is very little (about 3/4 of the way down the page):
http://www.houston-nissans.com/index.php?topic=953.0
Posted: Fri Oct 08, 2010 11:42 am
by Driftnasty180sx
my 2 cents
stock KA / SR trans- i usually break them at 400+ whp.
(please take into consideration that i drift my car and clutch kicking should be factored...well i would think)
Z32 trans with the MAZworks kit- I would say this is your best option. This kit comes with everything you need such as drive shaft and shifter placement.
RB25 trans has the internals as the z32 trans. In order to make the Rb25 trans fit the two top hole need to get drilled out a bit. Then you need the drive shaft made. (since i dont street drive the car i dont care about the speedo)
RB25 Belt housing could fit on the z32 trans but the shifter placement would be wrong and you would still need to made a drive shaft.
Posted: Wed Oct 13, 2010 11:23 pm
by Keegan
Parts shop max runs RB25 trans on KA-T in their green/white S14 campaign car. Just opened the holes up.
