HOW TO: *Properly* disconnect your PCV ...
bah might as well add my update.
i ditched the exhaust evac. who ever it was, was right. in boost its not doing anything. whoever it was had valid points and testing, and it got me thinking beyone basic theory. i begain to notice the only time my car would "dump the blow by" was as soon as i went back to vac. disconnected and it stopped, proof enough for me. i actually ditched it so i could take emissions, it was a blessing, after disconnecting it, the slash (with check) was still pulling in fresh air and allowed me to slam dunk the test.
currently im running PCV and VC to atmosphere, pretty much just b/c brian is and has been for so long. i def think the oil contaminates faster and needs to be changed more often. then again considering how hot i run it, its got to be changed often anyway.
- MTX450
Pulled out the PCV valve and just running to atmosphere?sdaigle240 wrote:bah might as well add my update.
EFI Tuner
Haltech Engine Management Systems
Why do you fellows say that just capping the ends on the bottom of the intake runners with rubber vacuum caps is not a good idea?
Is it because the turbo pressure can blow them off, or is there another reason?
I plugged mine off with rubber vacuum caps, since the hoses that are on there stock are rubber. However, my motor is just an N/A KA, so there should not be any pressure on them, only vacuum. Is plugging them off with just rubber plugs alright on an N/A motor, or is it still a bad idea?
Irony.cc
- orion
^^^ Rubber gets old and cracks, especially with heat. I had a couple sets on my intake manifold before I drilled-and-tapped it, and every year or so...I'd have to replace one.
It was usually in a gas station parking lot, in the rain .
Silicone vacuum caps will hold up better, but they can still pop off under boost.
In the very least, if you're gonna just stay N/A and cap them...buy quality silicone vacuum caps.
- Brian
- Brian
lol, wtf are you talking about?revolutionz_s13 wrote:because the stock pcv system is not enough for a KA turbo'd
It's a check valve that vents crankcase pressure. How do you have a pcv that "isn't enough"?
The reason people take it off is because it cleans up your intake manifold, and it's one lest thing to worry about going wrong....
As does any PCV setup. That is how they are designed. The only time they experience full open is at partial throttle. Low load and high load the valve is closed, or very close to it. Its how it works.revolutionz_s13 wrote:right, it also doesnt scavange any crankcase pressure under boost...the positive manifold pressure pushes the pcv valve shut. thats what i mean.
If you have a 1996 Nissan s14 KA24DE, the pcv valve is located up and behind the alternator, and in between the oil filter. A metal Check valve. It runs along with the IAVC tube. Getting in there is a bitchhhhh. I suggest you buy a bottle of coolant as well. The upper and bottom raidator hoses need to be removed, (it helped me a bunch)
That goes for all DOHC KA's.s14BEAST808 wrote:If you have a 1996 Nissan s14 KA24DE, the pcv valve is located up and behind the alternator, and in between the oil filter. A metal Check valve. It runs along with the IAVC tube. Getting in there is a bitchhhhh. I suggest you buy a bottle of coolant as well. The upper and bottom raidator hoses need to be removed, (it helped me a bunch)
damn this PCV subject has been the hardest thing to research for a 240 LOL!
ok i have 1 question, and im hoping someone doesn't give me a NICO answer
first off, we have no emissions in the great state of alabama, also i dont care about puking out my blow by all over the place. Also I running megasquirt so no maff and nothing else to worry about.
i would rather not run a catch can if possible.... this is more or less a weekend warrior i beat on.
Ive got my intake manifold blocked off to the tree. and i just left the PCV hose hanging. The valve cover has a rubber hose that runs to the side of the engine bay completely open.
now what is the quickest and easiest way of getting my crank case to vent?
remove the PCV fitting on the block and drill it out or replace w/ open one?
im hoping this will finally rid me of my excessive smoke between shifts.
i FINALLY found a picture of the pcv valve lol.
order a catch can and connect both the valve cover and pcv to a y adapter and go to catch can. take secondary catch can line to pre turbo preferably after maf if running draw through.
I will be doing this with can but venting to air.
I doubt it. I know people who just run a straight through fitting here with no check valve into a catch can.s14BEAST808 wrote:if this valve was to get stuck open or closed, would this cause idling and revving problems sometimes? Especially after car is warm
If you plan to vent to air, you should remove the check valve and put in a straight fitting. With my supercharger this is what I am going to do becuase of how my intake works, I will always be pulling high vacuum with it (regardless of throttle), so it is acting like a straight through fitting all the time anyways....supakat wrote:order a catch can and connect both the valve cover and pcv to a y adapter and go to catch can. take secondary catch can line to pre turbo preferably after maf if running draw through.
The PCV system is designed to fully open at high vacuum situations such as idle and cruising, which is 90% of the driving you do.
Under low vacuum and boost, the PCV closes to air doesn't revert back through the PCV.
So, if you keep the check valve and vent to air, it will just always be closed. Well not fully closed, but BARELY open. Due to this reason, youll get excessive blow by when cruising (ask me how I know =])... I am going to run a straight through fitting so that it can be flowing freely to the atmosphere during cruising and idling situations. Then under boost it will still be full open, but you don't have to worry about air going back in becuase it's vent to air and not hooked up to your intake system.
Incase you don't believe me on how a PCV system works, google it. It has a spring in the check valve so it closes anytime other than high vacuum which pulls against the spring.
Good luck guys. Hope this helps clear up some confusion.
Not sure if this has been posted, but has anyone used an exhaust driven crankcase vent setup like this?
http://www.summitracing.com/parts/SUM-1 ... mage=large.
I will be going this route next round of mods to my kat
This was on powerblock sat and sun.
http://www.youtube.com/watch?v=wGrx2rvIxJ0
and yes it was on page 6.
viewtopic.php?t=27437&postdays=0&postor ... &start=175
http://forums.nicoclub.com/pcv-set-up-t366874.html
Here's some researching i did a while back. its been more than 3years since i ran this set-up and my air/oil separator has been collecting blow by fuel flawlessly, preventing dirty blow by fuel from going to intake manifold-then to combustion chamber.
Theres an alternative by using pumps or exhaust pipe as a vacuum source to get the circulation for the pcv system to work properly, but most people keep on thinking that the pre-turbo pipe is a good source of vacuum.
Thats the setup I am doing with a high quality air compressor air/oil seperator (already have), however I haven't seen anything about people using a single seperator with a fitting tapped into the VC, a fitting where the PCV is, coming to a Y-block on inlet and the outlet going to mcmaster check valve to pre-turbo.
I can't see any issue with it, but I haven't done endless hours of research on it either.
1973 Datsun 240Z KA24DET
Build Thread:viewtopic.php?t=52102&start=0&postdays= ... highlight=
- rn240sx
Re: HOW TO: *Properly* disconnect your PCV ...
thats what i did and 3 yrs later, all 4 vacuum caps are still there, the clamps are still on and NO vacuum leak, idle is greatorion wrote:And the proper way is NOT to just remove the 4-into-one deal, and cap each bung with a vacuum cap. They will leak. They crack, then leak. They pop off.
