Blow through maf users check in
Post by TanManS14 »
Lol im sure he has tbolts.
undesiredshoe
Post by undesiredshoe »
T bolts and hairspray but I only used hairspray on the maf, t bolts work wonders everywhere else.
ImageStock block ka24e - 12.81 @ 113mph
s14dsm
Post by s14dsm »
:o just went blow thru after three years. wander why i didnt do it since day 1 :lol:
There is only one WINNER, And its the one who's up front
biggie
Post by biggie »
Unfortunately the Cobra MAF is plastic as well. I'll just be at 9-10psi after ebc though, so shouldn't have much trouble until I build an engine, hopefully.
'93 Coupe GT32e/'93 Vert/'03 G35C
Always Broke!!!
aaronlee97
Post by aaronlee97 »
I've pressure tested my MAF past 25psi without problems after I used window weld on it. Also, I haven't had any couplers pop off while driving since I've been doing the pressure testing. It saves a lot of hassle in the long run.
Anyway, here's a few pics of the current blow through setup.
Runs perfect without any fuel adjustment.
Post by TanManS14 »
Damn, i heard it was bad to go above 7psi cause of some other bla bla **** i cant remember. Does anyone else test there's up to the boost that they run at WOT? Cause obviously id like to leak test for the pressure its going to see if it dosnt harm anything.
2389cc_S14
Post by 2389cc_S14 »
Ive been running my car for over 2 years now with blow through set-up. Pushing 17 psi daily and I haven't popped a coupler once.
aaronlee97:
How did you route your power steering hoses?
~T3/TO4E, 50 lbs inj, Z32 MAF, Enthalpy ECU, JGS mani, 8.8:1 Arias, Apex GT Spec Exh
all shal perrish
Post by all shal perrish »
TanManS14 wrote:Damn, i heard it was bad to go above 7psi cause of some other bla bla **** i cant remember. Does anyone else test there's up to the boost that they run at WOT? Cause obviously id like to leak test for the pressure its going to see if it dosnt harm anything.
lay off the weed son. LOL
www.autovaughnperformance.com
if you have some, pm me
el_mata
Post by el_mata »
lol
Post by TanManS14 »
Bwhahaha, lol, i can articulate a sentence in any state better than you can kiddo.
Plus who the ***** listens to a person that flies kite's and has a foo man choo.
bwhahahahhahahaha, that sh*t is f*ckin raw though, i gotta admit.
all shal perrish
LMAO BUAHAHAHAHAHAHH
i just bought some more kites too.. i actualy just blew 600 bucks on kites and 500 bucks on a skateboard.. lol.. i guess no built motor for me :(
Last edited by all shal perrish on Fri Feb 26, 2010 10:23 pm, edited 1 time in total.
Post by TanManS14 »
Bwhahahahahaha truce truce. God we're cool. ight im takin yours down senior foo man. I'll quit takin up bandwidth, eventually when your thread is old ima bump it though you vagina.
all shal perrish
TanManS14 wrote:Bwhahahahahaha truce truce. God we're cool. ight im takin yours down senior foo man. I'll quit takin up bandwidth, eventually when your thread is old ima bump it though you vagina.
took yours down too HHAHAHAH and, i dont care if you bump it. ill just delete my account BUAHAHAHok
end thread jack
Jay240
Post by Jay240 »
undesiredshoe wrote:T bolts and hairspray but I only used hairspray on the maf, t bolts work wonders everywhere else.
This might seem like a crazy question, what brand or type of hairspray do u guys use ? i dont use hairspray so i have no clue about it. What is another alternative to hair spray ? can i use window weld to help hold the piping unto the maf ??
aaronlee97
2389cc_S14 wrote:Ive been running my car for over 2 years now with blow through set-up. Pushing 17 psi daily and I haven't popped a coupler once.
aaronlee97:
Well, I basically found the hose ID and got some from autozone which will work fine with Power Steering Fluid. Then I just removed the stock ones and popped the new ones on and routed them to the location I wanted it to be.
undesiredshoe
I used the hair spray in a pressurized can...I got it from walgreens for $1.
Jay240
Post by Jay240 »
thanx bro
THR
Post by THR »
You cant be serious? :lol:
Are you guys using hairspray on the MAF then connecting the coupler and tighten the clamp?? :!: So its sticky icky is making the coupler hold better against the MAFs plastic shell?
//Patrik Sthlm / Sweden
biggie
Post by biggie »
THR wrote:You cant be serious? :lol:
Used at the MAF and all the other couplers.
Always Broke!!!
THR
Post by THR »
So couplers on steel/alu as well??
biggie
Post by biggie »
Yes. When drying hairspray ends up being like a glue/sealant combo.
Always Broke!!!
ditchs14
Post by ditchs14 »
hey guys. quick question. what are you guys doin this these then
are you still running them?
Jordan Gladman
Post by Jordan Gladman »
Mount it to your pre turbo intake pipe.
For the guys spraying hair spray on their IC connections, dont get any on your MAF!
PuNcHdRuNk
Post by PuNcHdRuNk »
i was blow through for about 2 months,i kept getting boost leaks from the maf cover,i even used windshield urethane to seal it.
Mamba
Post by Mamba »
i have a question/issue. i set my car up in the blow-through manner. only problem is (and id like to know if anyone had the same issue) i have large cams (BC 272 272) they are dialed in with the jwt cam gears etc. Problem: the car wont stay idleing for more than 10-15 seconds then she dies. if i disconnect the Ic piping she runs like n.a.
is it possible that because of the exhaust pulses and turbo pulses the maf gets confussed?
Post by TanManS14 »
How close are your bends to the maf?
It could be possible that you are too close, and when you pull off the cold pipe before the maf you are no longer getting any air disturbance since the bend cannot affect it anymore.
marko76
Post by marko76 »
Sorry for the stupid question,,,, but what is a "blow through" set up?
Ka stands for: Kicks A$$!!
Post by TanManS14 »
Though you could've found out by clicking a page or 2 back, and looking at where the maf is...
It is where you put the maf in the intercooler piping, rather than on the inlet of the turbo. Usually, when its on the turbo it is sucking the air through the maf, hince, pull through. When it is on the intercooler piping, you are essentially pushing or "blowing" air through the maf when under boost.
marko76
Post by marko76 »
Ok that clears it up, for me. thanks!!
Mamba
Post by Mamba »
i have about 5-6 inches infront and after the maf. the only thing i can think of is the pulses of air, its not a constant air flow? today ill try pre turbo.
