heelp wit new motor
heelp wit new motor
jus got finishin rebuilding my kade a few days ago..just got it 2 start and run but it doesnt seem like it gettiin oil pressure..how do i check it other than takin the front cover off again"??this really sucks cuz it sounds soooo mean runnin.. but it ran for a lil and shut right off like it had a vac leak or no maf..heeeeeeeeeeeeeeeeeeeeeeelllllllllllllllpppppppppp!!!!!!!!
tryin to get an idea so i can atleast drive my car around till i get tuned..some one help me out.n60 maf, brand new afc neo,2 in 5 out for hotwire..thats what i found..the idle is kinda crappy when its cold its idle pretty decent but when it warms up it start runnin ruff and idlin crappy..then when u go to rev it it revs fine but when it goes to settle at idle it stumbles and sometimes stalls..it has 370 inj,excessive intake,10:5 90 pistons,headers,exhaust..have a ruff and kinda low idleround 7-800 instead of 950-1000.. soon as i push the clutch in its starts to bog,stumble and wanna stall out..heelp! ben tryin to figure this crap out for the last month...!!!!!
if it had alot of miles on it i woulda replaced the oil pump. 1 because its a bi*ch to do after uve allready reinstalled motor.2 cuz they are not expensive.
and a ka is supposed to idle @ 750 not 900-1000.
currently n/a.
currently n/a.
If you don't have an idle valve you'll have to keep your rpm's up a bit at cold start to keep the car running...once it is a little bit warm, it should idle on its own. Your idle will constantly be at different rpm ranges, though, because the computer has no control over where the car is idling after you remove your idle valve.
