How to build a KA24DE
Postby koukika240sx » Wed Nov 02, 2005 5:42 pm
ARP studs do not stretch. thats why they are reusable.
koukika240sx
Postby rhd » Wed Nov 02, 2005 5:54 pm
are you talking to me?
and yes, arp's do stretch...they just arne't tq to yeild. ALL bolts stretch
rhd
Postby joshds25 » Mon Jan 23, 2006 5:27 pm
i just wanted to post on this thread agin to bring it back to life this should have been a sticky??? what you say? :!: :arrow:
joshds25
Postby Kilten_one » Mon Jan 23, 2006 6:25 pm
joshds25 wrote:i just wanted to post on this thread agin to bring it back to life this should have been a sticky??? what you say? :!: :arrow:
a link to this thread is posted in the hall of fame under engine parts related
Kilten_one
Postby joshds25 » Mon Jan 23, 2006 6:32 pm
opps sorry :roll: my bad
joshds25
Postby jdmpurest » Tue Jan 24, 2006 12:23 pm
dont foget to always assemble your engine in an environment that is 68.4 degrees celcius. that is the temprature of the engine build room at the factory.
jdmpurest
Postby doggunracing » Tue Jan 24, 2006 12:46 pm
jdmpurest wrote:dont foget to always assemble your engine in an environment that is 68.4 degrees celcius. that is the temprature of the engine build room at the factory.
Wow, it's 155.12 degrees fahrenheit in the build room? I would go on strike... :lol:
'97 SE SC50 KA-T
doggunracing
Postby Marcus » Tue Jan 24, 2006 12:51 pm
That's what I was thinkin....that has to suck.
Hell I'm in Kansas so it's that warm in the summer anyways. 8)
Marcus
Wearer of Missing G-Strings!
Postby ispentallmymoneyontires » Tue Jan 24, 2006 11:49 pm
so basicly i can build an engine any time outdoors here in florida, sweet.
-joking
RIP 480sx
Postby felix » Wed Jan 25, 2006 6:24 am
very best post ever. i'm about to do this myself and need all the help i can get!
thanks alot
felix
Postby tunedis95 » Sun Jan 29, 2006 5:10 pm
wow ....this is freaken awsome....i've been looking for something like this....great job on the write up...great pics too.....eric
ZENKI!!!!CHOUKI!!!!!KOUKI!!!! and 350ZZZZZZZZZZZZZZZZ
tunedis95
Postby EstoMax » Mon Mar 27, 2006 9:42 pm
hey man with the ring gap you mean 0.017 and 0.019 right not 0.0017 and 0.0019? :o
and also wouldnt you want the first ring to have more clearance (since more heat hits it) instead of having first ring a little less gap and 2nd ring more?
Marko
95 s14 kaT
t3/t04e (60 trim), bikirom, groundzero mani/dp, 82 lb AMS FS
94 d21 kaE 4x4 stock
EstoMax
Postby Java » Tue Mar 28, 2006 6:59 pm
Ive got a question (like i always do) Whats tools did you need to have to assemble the short block? measuring wise. Im doing mine very soon (like in a few days) and i was curiouse what all i would need other than a ring compressor and a fealler gauge.
240'less, I may have lost the battle but the war is not over yet!
Java
Postby EstoMax » Tue Mar 28, 2006 8:24 pm
you also need a file to grind the rings down.. a hand one will take a long time, i set a dremel up sideways and used that, only put the ring end on there for 2 sec at a time and then go remeasure cause it eats it down quick :D
95 s14 kaT
EstoMax
Postby Joel07 » Wed Mar 29, 2006 6:33 am
The idea behind a larger second ring gap is that combustion gas tends to get caught in between the top and second rings, and if it builds up enough, will cause the top ring to "flutter" and lose seal. So by opening up the second ring slightly, the small amounts of combustion gas just go into the crankcase rather than making the top ring lose seal. This is the same reason I will never use gapless second rings in a motor, and the same reason many pistons have a groove cut between the top and second rings.
Joel07
Postby Java » Wed Mar 29, 2006 10:51 am
why does the sound of that scare me :? grind down the rings.. I guess i need to some research on that :lol:
Java
Postby Projex240 » Wed Mar 29, 2006 1:30 pm
mine are at 22 and 22
Its what ivan told me would be a good rign gap with boost and nitrous.
-Josh
Projex240
Postby LocAss24 » Fri Mar 31, 2006 9:04 pm
Wow, great post. Thank you for putting out the time for this. You've just given me that little extra encouragement to rebuild my spare KA.
LocAss24
Postby wildbama37 » Sat Apr 01, 2006 12:41 am
Projex240 wrote:mine are at 22 and 22
-Josh
GRIND down the rings? are you serious? is this really a good idea ?
wildbama37
Postby SleepyS-14 » Sat Apr 01, 2006 12:44 pm
It is a requirement. You have to set the ring end gaps correctly. Just take your time because if you nick the actual ring surface(that contacts the cylinder wall) then you have to get a new ring.
SOHC S-14...
SleepyS-14
Postby EstoMax » Mon Apr 03, 2006 5:53 pm
btw do you also lube the rod bolts with the arb lube or do you leave those dry for torqueing?
95 s14 kaT
EstoMax
Postby SleepyS-14 » Mon Apr 03, 2006 9:23 pm
You have to use the lube. A dry torque is not an accurate torque.
SOHC S-14...
SleepyS-14
Postby Java » Tue Apr 04, 2006 8:16 pm
where did you buy that plasti gauge :oops: im also reading that they have different packages PL-A, PL-B ect. ranging from different measurments i imagine. Where did you get yours and what package number did you get?
Java
Postby wildbama37 » Tue Apr 04, 2006 10:39 pm
bump for the plastigauge question!
wildbama37
Postby ghostchild316 » Wed Apr 05, 2006 7:30 am
You can get it almost any parts store.Trust me,I know,I work at an auto parts store... :wink:
Dead account. Send pm's to "Alonso" from now on...
ghostchild316
Postby Java » Wed Apr 05, 2006 9:21 am
what mm package should i be looking for? they have for example: .010 through .050 next mm package would be gauging from .060 through .100 Dont know if I explained that right or not but i think youll know what i mean. Basically i dont know which mm im looking for to measure what i need to for the assembly of the shortblock :oops:
Also one more question, what did you pay to have the block: Hot tanked, magnafluxed, bored, honed, and redecked. Im having mine done at a local shop and they quoted me $900+ for Rods/Crank ShotPeend, Block Tanked, Maged, Bored, Honed, Cleaned, and Balanced. I thought at first they included assembling it aswell.. but i called them and they said it didnt.. does $900 sound right for all that???
Java
Postby NHn00bie » Fri Apr 07, 2006 1:08 am
bump for plasiguage package ???? and is decking nec. when building?
NHn00bie
Postby wildbama37 » Fri Apr 07, 2006 8:00 pm
i guess just look at what the clearances are SUPPOSED to be and then by the plastigauge that has the clearance within the range of the plastigauge
wildbama37
Postby lestat » Thu Sep 21, 2006 9:46 pm
great post. you are my hero.
lestat
Postby Ngen-Head » Fri Dec 01, 2006 12:00 pm
pics dont work, anyone know why?
Ngen-Head
PreviousNext
Return to KA-T Tech. Advanced
Users browsing this forum: No registered users and 78 guests
