How to build a KA24DE
Postby Walperstyle » Sat Nov 01, 2008 11:40 pm
^has anyone called ARP yet? I was going to order some but am waiting because of this.
Btw, THANK YOU FOR THIS THREAD, SOME BASICS ANSWERED!
Postby TryingToTurbo » Sun Nov 02, 2008 9:55 pm
yeah,, deuceforty got it sorted out. i think he ordered them from phase2motortrend.com and they sent him some that were the right thread pattern, but not for the ka. he sent them back and got the right ones.
in other words. i think it was phase2's fault not ARP that he got the wrong studs...
http://www.ka-t.org/forums/viewtopic.ph ... sc&start=0
TryingToTurbo
Postby drunknmunky » Mon Nov 03, 2008 6:51 am
I got a question about takiing off the head. There are those 2 main nuts with the 3/8" square socket. Then there are those 8 individual caps which hold the studs from the short block to the head. Are those allen wrench socket holes????
drunknmunky
Postby memphis » Mon Nov 03, 2008 3:31 pm
sick thread i love it. thanks!
'96 Build ka-t, '05 Evo RS 35R.
memphis
Postby chuki_beast » Tue Mar 31, 2009 11:08 am
great thread...very informative. I'm relatively new to this stuff. I understand everything that you did, but I got a couple questions.
1.What does bored and honed mean? My understanding of bored just means to make the cylinders bigger?
2. Also .....If my plans come through and I do get a S13 and rebuild the engine. I'm wondering if it is necessary to bore the block. Can I re-build the block without boring if I'm going to be running it NA with the expectations of do a turbo upgrade? Or would the block need to be bored when I'm doing the turbo upgrade?
and I guess I should ask this question as i'm already on a roll. lol
3. Can the fuel system be upgraded if I'm not going to be running turbo or with this lead to complications. Should I just wait till I do a turbo upgrade to install a new fuel system? My goals are going to be somewhere in the 200 - 250 HP region I think. Give or take.
chuki_beast
Postby chuki_beast » Tue Mar 31, 2009 11:12 am
jdmpurest wrote:dont foget to always assemble your engine in an environment that is 68.4 degrees celcius. that is the temprature of the engine build room at the factory.
is this true?!?!?!?!
chuki_beast
Postby drftturbo » Wed Apr 29, 2009 10:09 am
Don't forget the o-ring between the timing chain and the block, and always use a new one....
if you don't your motor will last about 150 miles... oil starvation, then knocking..
4NROKET <~~~~
Click here~~~>Image
drftturbo
Postby 2point4turbo » Wed Apr 29, 2009 11:37 am
umm what o ring between timing chain and block?? your picture doesnt work, and im confused on what your talkin about..
2point4turbo
Postby ka-torqy » Wed Apr 29, 2009 1:48 pm
yea me too bout the o-ringe between the chain and the block
ka-torqy
Postby Unbound Yuurei » Thu Jul 30, 2009 8:15 pm
how long did it take you to finish building the block?
how many hours did you put aside per day to work on it?
Unbound Yuurei
Postby merlin240s13 » Sun Aug 02, 2009 12:02 am
search boys
merlin240s13
Postby Unbound Yuurei » Sun Aug 02, 2009 4:56 am
merlin240s13 wrote:search boys
bah, ok....
T_T
Unbound Yuurei
Postby R33E8 » Fri Aug 14, 2009 10:07 pm
Just to save people the hassle of search across different sites, here is a link to the o-ring they are talking about:
http://forums.nicoclub.com/zerothread?id=191269
R33E8
Postby merlin240s13 » Fri Aug 14, 2009 10:23 pm
lol i had no idea what you all were talking about I was just being a jackas s :D
merlin240s13
Postby yadonnome123 » Mon Sep 28, 2009 1:28 pm
this writeup helped me alot during my rebuild. I printed this and used it alot. very helpful. thanks
yadonnome123
Postby kentoJDM240 » Thu Nov 05, 2009 5:41 am
Can any one view the pictures? I clicked on the link and getting a page cannot be displayed Let me know if its just my pos PC
thanks
1995 240sx se. Engine out
1990 SOHC Sold
01' Celica GT-S : CAI, Exhaust.
kentoJDM240
Postby 200sxBoY » Tue Nov 10, 2009 7:11 am
sweeeeeet build
200sxBoY
Postby mykal90 » Tue Mar 16, 2010 8:34 pm
thanks man my motor is rebuilt and running good bc of your help
mykal90
Postby DeBoy » Thu Apr 22, 2010 9:25 pm
I shall def be using this someday. thanks much.
DeBoy
Postby vdub » Fri Apr 23, 2010 9:21 am
i have a question, if bearing clearances are off does this mean that the block or crank are bad? do clevite and acl sell different sized bearings to fix clearance issues? if bearing clearances are wrong what exactly happens like u spin a rod bearing or main bearing.
probly noob questions but im a noob so bear with me
vdub
Postby Walperstyle » Sun Apr 25, 2010 10:18 pm
^Its been answered here. Search engine should pull up results, but to answer your question;
Clevette has only the one type of bearing. Nissan has 3 different grades. (see the FSM). There is a possibility you need to get a different sized bearing, but if it still has too much 'play' after torqued and checked with plastigauge (or a micrometer check) then you should source a different crank, or find someone that can make custom bearings. Finding a different crank is easier. AMS told me to find a different crank if I still had clearence issues.
I'm kinda in the same boat. My clearance with micrometers was showing about 0.0030 on average, however I double-checked with plastiguage and it seems to always read 0.0020-0.0025 approx. I'm going to proceed with my build, but throw a large magnet in the oil pan and check it while changing oil a few times during the break in process.
FSM calls for a max of 0.0024 clearence, and min 0.0004, sometimes turbo motors can get away with a little more (but proceed at your own risk!
Postby NateDogg » Sun Apr 25, 2010 10:31 pm
Just run a bit thicker oil if you have larger clearances.
10w40 or 15w50 should do the trick, depending on oil temps.
'91 S13
Built, balanced KA-T
NateDogg
Postby Juank39 » Mon May 10, 2010 5:00 am
BRAD D wrote:
onefast240 wrote:You can but with the gear on it makes it much much easier to keep the motor and timing all good.
The way you posted is how the FSM says to do it as well.
I think it would be easy to mount up the gears / chain and then put the covers on... this way the chain cant jump off....
So I can do it that way? Or no
Thanks, super good post
so my dumbass did one of these, but honestly im about to give up on this motor, the headgasket snapped from so much bending rite where it ends at the head, do u guys think it would be safe to slap some liquid gasket to seal between the upper and lower timing chain covers???
Juank39
Postby schmauster920 » Mon May 10, 2010 11:13 am
yes, as long as the head gasket area is undamaged... the front covers have always sealed up fine with rtv
Postby Inferno s14 » Wed Aug 04, 2010 11:22 am
YOU THE MAN, MANNN!!
Inferno s14
Postby ChiefS13DE » Wed Aug 04, 2010 8:48 pm
I got a question for ya, could be a noob question, I dunno. I'm building my block, here is the parts list:
Wiseco pistons, std bore
clevite bearings
bc con rods
arp head studs
Soon to have:
Holset HY35
JGS starter kit
ebay IC
Goals are 350hp, maybe more, depends on how content I am with it after the build.
I have the ARP HEAD STUDS, but no MAIN STUDS. If I used stock main studs on the girdle but ARP head studs, would I have issues with the crank holding 350hp+? I don't believe the head would lift, but I'm just wondering if I should get ARP mains as well. Thanks for the input guys.
ChiefS13DE
Postby Walperstyle » Wed Aug 04, 2010 11:23 pm
the tune will determine your horsepower. Mains should be fine, but for what its worth, I'd do it anyways.
Postby ChiefS13DE » Thu Aug 05, 2010 3:47 am
True. I looked it up on frsport.com and they're about $110 for main studs. I guess that's a small price to pay for piece of mind. Thanks for the advice man.
You can lay bricks for 10 years but never be a mason; but you suck one **** and you're a ****sucker for life.
ChiefS13DE
Postby Burnt240sx » Mon Oct 11, 2010 9:59 pm
SleepyS-14 wrote:You have to use the lube. A dry torque is not an accurate torque.
Really?.... From what I was taught, and im by no means weak when it comes to mechanical. I though dry torque was the actual when you do a wet/oil torque you are actually increasing the torque of the bolt. But it is all in the specifications of the manufacturer. So if arp said use oil or lube then use lube, if it said dry, then you would do it dry..Correct?
Burnt240sx
Postby schmauster920 » Mon Oct 11, 2010 10:36 pm
This goes for everyone if its not obvious... check the torque on your mains, rods and anything else if you have the pan off already.
I checked my main bolts when the motor was out and they were at about 20ftlbs, some were even looser.. I think they go in the 50ftlb range.. either way they were loose
Last edited by schmauster920 on Fri Apr 15, 2011 10:14 am, edited 2 times in total.
PreviousNext
Return to KA-T Tech. Advanced
Users browsing this forum: No registered users and 53 guests
