C4 AUTOMATIC ON 240SX S14
Whats up guys, i was reading up on some posts of people running Ford C4 autos on a ka. any one have some more info on that. i have the C4, AMS adaptor plates and Xmember with the bellhousing, but was wondering if someone could get me some pics of their setup and what they recommended for gearing/ converter. im running 4.08 now with a Q45 connverted rear. also whats the best shifter to run and if they recommend a certain drive shaft. the Motor witll be around 750hp.. also how stretable will it be with the 3speed..
thanks for any and all your help!
Frank
Frank
- Kamilitaryman
pm efeezi or elks240 i think they both ran c4s.or scroll through the 600+ post if u search "automatic tranny."
currently n/a.
currently n/a.
*cough* viewtopic.php?t=1553 */cough*
well 750 hp is not very street-able. You will have a very small power-band. but it will be drivable on the street but you will have to have a high stall converter and you will be turn high rpms cursing on the highway.
˙ʞɔɐq ǝdıduʍop ɥɔuıᄐ llnɟ 'ᄐʌıısɯ 'ɔɔ0ㄥᄐ ɹs '8ᄅʇ ㄣ⇂s 'ʇunoɯ ɯoʇʇoq ᄅʇ ɔɐss 'ǝdnoɔ ⇂66⇂
EviltoM wrote:this is the dumbest ***** post ive seen this year. congrats.
- TinyT
ok, no, and what?oilman wrote:well 750 hp is not very street-able. You will have a very small power-band. but it will be drivable on the street but you will have to have a high stall converter and you will be turn high rpms cursing on the highway.
do you have any idea about choosing a stall converter? it is very case specific, but going to a HUGE stall is going to do nothing good for you unless the motor is reving very high. and how do you know he is going to have a small power band? do you know what turbo he has and what he is spinning the motor to? with that said, lets have a little more info about the ka, its turbo setup, and what you are going to spin the motor to. and why would he be cursing on the highway? a 3 speed with that gear will go down the freeway at a plenty descent rpm. also, why is 750hp not streetable? kedbmx daily drives his rig with a/c and 700 some whp.
oilman, id just step out of this convo now...
still need some more info. There are alot of calculators to help you pick out the stall that you will want. If not, get a close estimate of how the power band is going to look by answering all the questions then you can simply call whom ever you wish to buy the convertor from and give them all the info about the car and they should be able to point you in the right direction for choosing the correct converter.
- Forum Moderator
either run a tighter converter (lower stall) + nitrous or loose converter (higher stall) + transbrake (no nitrous)...both have there advantages/disadvtanges.
just send an email to Brad Davies...look at his profile here: http://ka-t.org/brad_d.php
Show me a auto ka with 700whp+ that doent have a 2000rpm power band. Also show me a auto ka that runs anything less then a 3500rpm stall on a c4, oh you cant and you never has a high hp car with a auto have you. Yes you can daily drive a 700 whp+ car but you cant afford the race gas to run it up to 700whp on the road i should of stated you can but it will cost you your first born if you have the boost up to make 700whp.TinyT wrote:ok, no, and what?oilman wrote:well 750 hp is not very street-able. You will have a very small power-band. but it will be drivable on the street but you will have to have a high stall converter and you will be turn high rpms cursing on the highway.
Ok so your saying that it doesn't spike in power.without seeing a graph you might have a 3000rpm power band my god.crazys14 wrote:i have more than a 2k power band.. i make 200whp at 4k and 500whp at 5k and 710whp at 7500
200whp at 4k wow thats a 50 hp over stock so i wouldn't say you have a great wide power band.
200whp @ 4000 bro.......stock is 155 @ like 6800.and 500whp @ 5000,700+@7500.............btw 4000rpm to 7500 is 3500 rpm pb.sounds pretty badass to me.oilman wrote:Ok so your saying that it doesn't spike in power.without seeing a graph you might have a 3000rpm power band my god.crazys14 wrote:i have more than a 2k power band.. i make 200whp at 4k and 500whp at 5k and 710whp at 7500
currently n/a.
currently n/a.
auto ka's will have more than 2k power band and im not asking if a 700hp KA will be streetable, im askin how streetable will the KA be with the C4 in it and lets say a 5500 stall converter on it.. just cuz you have a 7-800hp car does not mean your going to be boosting off the green light and goin to BK and 2 steppin in the drive tru...lol
ive thought that a pglide would be awesome for a drag set up but would be killing some rpm's on the street.not very streetable imo.smracing wrote:Id run a powerglide with a low first gear before Id run a c4. With the right convertor, the powerglide will be quicker at your HP levels. I've swapped 2 turbo mustangs (one 2.3, one 347) from 3 speeds to powerglides. Both picked up ET.
currently n/a.
currently n/a.
- smracing
Both were street cars, and trust me, you won't be able to tell the difference between the two or three speed with the right convertor. They would have close to the same first gear, and have 1:1 for high gear. What's not streetable about that?boker240 wrote:ive thought that a pglide would be awesome for a drag set up but would be killing some rpm's on the street.not very streetable imo.smracing wrote:Id run a powerglide with a low first gear before Id run a c4. With the right convertor, the powerglide will be quicker at your HP levels. I've swapped 2 turbo mustangs (one 2.3, one 347) from 3 speeds to powerglides. Both picked up ET.
