Turbo choice 600+whp
whats going on everyone? its been a while since i asked a question here but im back in the ka-t game and im re-doing my ka-t setup over the winter and i need help to pick a turbo.
some background:
motor built ka-t
wiseco 8.8:1 .20
crower i beam rods
cometic head gasket
arp 10mm head studs
ported head.
tuned hks fcon pro V
740cc nismo injectors
255intank
currently the car is on a gt3582r t3 .82 on 14psi makes 366whp .
goal: 500+pump / 600+e85
new setup:
full race manifold
new turbo
full race downpipe
tial 44mm wastegate
custom surge style intake manifold
90mm tb
new shorter charge pipes/flip i/c
-8/-6 fuel lines
top feed fuel rail
1000cc i.d. or possibly 2000cc
aeromotive fpr
dual bosch 044 pumps in line
fuel filter
surge tank
-6 an lines from fuel to surge to fuel pumps/ -8 to fuel rail.
so with my new setup and current engine setup up which turbo would be more efficient at making my hp goals at less psi:
im looking into the precision 6466 bb twin scroll .82 t3. also considering a 6766 t3 as well.
please let me know your opinions /reviews on either turbo and what you think would be best for my goals.
some background:
motor built ka-t
wiseco 8.8:1 .20
crower i beam rods
cometic head gasket
arp 10mm head studs
ported head.
255intank
new setup:
full race manifold
new turbo
full race downpipe
tial 44mm wastegate
90mm tb
-8/-6 fuel lines
top feed fuel rail
aeromotive fpr
fuel filter
surge tank
R.i.p. 97 s14
96 s14 ka-t
Why not up the boost on the 35r?
1000cc is not going to get you 600hp on e85. Go with I'd 2000s and be done, gives you room in the future.
Here are some setups u can look at.
viewtopic.php?t=4303
Btw I thought wiseco pistons were 9:1?
now that ive looked up my options i really don't have much choice since i already bought the full race manifold.
not much options for divided t3 turbos. so i think what i may have to do is but atp new 1.06 divided t3 housing and use it on my 3582r.
i think i can maybe squeeze 600whp out of this turbo on 30+psi and maybe 500+ around 20psi pump.
if not then i have to go with a no divided precision turbo.
yea the e85 thing is tricky i dont know what injectors to get that are good for pump/e85 thats over 1600cc, only thing is i.d.2000cc but it cost alot. i may just have to bite the bullet and do it.
R.i.p. 97 s14
96 s14 ka-t
I used the old saturn style arp bolts that are rated at 190,000 psi and it lifted the head at 29psi 665whp I upgraded to the ka 220,000 psi bolts but have yet went back to the dyno. I'n building a new motor which I will use l19's cuz I dnt trust the 10mm. 1600cc injectors should be good for up to 700whp I read a few guys hit 800whp with the ev-14's which is what I have since you can bump the fuel pressure up higher then the crown vic's. They run more than half the price the id2000's go for
hmm so looks like my setup on pump gas i may be limited to 22-25psi, i hope i can make 500+whp on this boost level.
im going to change my back housing on my turbo to 1.06 divided t3 and see how i like it. if i dont make over 500whp on pump im selling that turbo and getting ither a non divided s366 or a 6466. with ither of those two turbos i should be able to make over 500 hp on less then 25psi pump and 600+e85.
for injectors im looking for good 1600cc injectors with good resolution down low for driveability. i really dont want to spend 1g on id2000cc but if i cant find the right injectors then i may have to.
my head studs are really making me thing if i can get more then 25psi before head lift. :/
R.i.p. 97 s14
96 s14 ka-t
Check kedbmx if I'm not mistaken he's still selling the id2000 with the right plugs for 670 shipped. Talk about a hook up. I know because I pm'd him recently and he's still selling it for that price. I just need to grab a set from him now lol.
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Cxracing fmic
Proefi pro128, e85 flex fuel
K1 rods
Cxracing fmic
- all shal perrish
One walbro 460 in tank will do it, that's what I'm using same injectors tooturbo2nr wrote:yea i think i should be ok on 30psi.
question:
is 2 external bosch 044 pumps overkill to make 600whp on e85 with id2000cc?
www.autovaughnperformance.com
if you have some, pm me
His head or block was o ringed also. Just forgot which one...Legit6MT wrote:If I'm not mistaken efeezi was also on 10mm ARP studs and ran 40psi and made 775whp thru a C4 trans, but I think they are rare scenarios. You shouldn't be afraid to go past 25psi. Get a s372 it'll do just fine even on a street car
Psi is going to vary depending on the turbo. Theres ppl making 400whp on 30psi with
turbos. Heads lift from cylinder pressure my guess would be keep it under 700hp even 650 just so no coolant overflows. I have yet to race my car with 665whp but 580whp is very fast at least until you bring out the 2jz
yea i figured it varies with different turbo's 30psi on a 35r is very different then a 30psi on 42r..
ill keep "600whp or ~30psi" my safe limit for this 35r. i just hope this damm 1.06 divided helps me squeeze a little more power out up top.
i really wish now that i didnt buy a full race mani and just did a custom divided t4. i would be able to make 600hp so easily on 25psi with a 6766 -_-
. so much involved with making a 600whp car or maybe im over thing everything lol
-RosadoRacing , id love to see your car in person hopefully ill bump into you and the car next year at a track day or something
R.i.p. 97 s14
96 s14 ka-t
how high you gonna take the boost on 93? i always seemd to think people didnt push it much past 22-23? i even catch the occasional eye roll with your running 18 on pump!?
- Walperstyle
yea i know the 3582 will make 500whp but around 30+psi of boost., thats a little high for my taste.
the reason for the twin scroll is to make full use of the twin scroll manifold mainly and secondly to give the car a little more up top.
i plan on chopping my intake manifold up and making a better flowing manifold w/ velocity stacks. right now my stock cams are limiting me, ill probably do kelford 272 before i get a final tune , but im just trying to get the rest of the fuel system done first.
R.i.p. 97 s14
96 s14 ka-t
yup!! pretty much why i feel like i wont stay KA forever.turbo2nr wrote:id love to make big power on pump but it doesnt seem likely.
e85 in nyc is getting more popular but still not readily available. i tend to drive the car alot and far when i do drive it so the last thing that i would want to happen is to run out of fuel and get stuck.
i dont really like the idea or always having 5gal extra of e85 with me, esp if im in the middle of no where.
this is where flex fuel would be amazing but aem v1 doesnt support it.
can you do a dual map on aem ( e85/pump?)
R.i.p. 97 s14
96 s14 ka-t
