Z32 trans kit with White Bunny clutch- starter problems
- wannaboost?
Recently I converted to the z32 trans setup using an Xcessive kit. I have had starter issues since day 1. About half the time you try to start it, the starter engages but doesn't turn the engine over. Instead, it makes an extremely loud grinding noise. I always thought that it had something to do with the flywheel-starter contact area (they state that some flywheels may need the teeth on them machined to help the starter grab).
Well after pulling the trans off, I have found that the starter has been catching the pressure plate on it's way to the flywheel teeth. This explains why the grinding noise happens about 50% of the time. The only reason I can think of for this would be the larger diameter "White Bunny" z32 clutch setup I'm running is just that much wider than the stock pressure plate. I've also concluded that the reason a stock trans doesn't mind the diameter of a White Bunny setup is because the starter engages on the back side of the flywheel and the z32 kit has the starter engaging from the front side of the flywheel.
Has anyone had these kind of issues before, and what did you do to go about fixing it?
And if not, I hope I've at least saved someone some trouble.
Build.Boost.Break.Repeat.
Nis720 fitted his with the starter in the stock orientation like this:
Granted he was using a Mazworx adapter plate and a truck with a SOHC, but maybe the xcessive adapter could be modified to accommodate the starter in the stock location? Do you have any pics of the trans with the stater installed?
Link to trans mod on his build thread: viewtopic.php?t=45564&postdays=0&postor ... &start=200nis720 wrote:Test fitted the starter,
Re: Z32 trans kit with White Bunny clutch- starter problems
Good thing to watch out for in the future for me
well thats not good... because i got the white bunny but soon was going to upgrade to the z32 transmission... let me know how this works out for you
- S14wayz
Did you manage to fix it? Im planning to go with the same setup but dont want to run into this problem
after looking at this again, maybe the issue is the pressure plate... is it overlapping the teeth on the flywheel?
what clutch is it?
what clutch is it?
- wannaboost?
Hey guys,
I have not had a chance to dig further into this situation yet. I will try and post a solution whenever I do.
The pressure plate does not stick out near the flywheel teeth.
The clutch is a stg 4 comp clutch for z32.
- S14wayz
yes please, keep us updated! Going to be doing the same thing pretty soon and don't want to run into the issue or atleast be aware of itwannaboost? wrote:Hey guys,
Did you use both shims that came with the kit? I did not read through but I do not have issues with grinding.
- wannaboost?
Which spacers did you receive? Are you talking about the flywheel spacer and the large bellhousing spacer/adapter? If so then yes, I'm using those. I still haven't looked into this. I will most likely fit the starter on engine side (factory location) somehow and post up how I did it.
These.
I just lost another starter today. This is the 3rd one. I am going to cut out the starter hole for the starter to fit in just right rather than drilling new mounting holes on the starter.
Check out what Rosado did.
viewtopic.php?f=40&t=57938
I drove the car to work Saturday morning. I went to leave and no go. Starter shot. So today, I had some time and I notched out the bell housing so the pulsar starter can go right in. I only have to modify the starter on the bottom bolt hole. After completing this, it turns great. It is actually faster than previous new starters.
Since we create two new mounting points on the starter, it changes the angle of the engagement which probably hurts the solenoid by adding more stress. My last starter solenoid did not even eject. It stuck. When I opened the starter, I can see a groove that was made by the solenoid engaging. So hopefully by using the stock starter mounting holes, the angle is where it needs to be. Only time will tell.
I get faster starts and it sounds healthy. Here is how I modded my housing. Hopefully the stater lasts like it is suppose too.
- S14wayz
thanks for that post^ ill definitely give that a try when i get my kit
No problem. Still starting strong.
- wannaboost?
I did not receive and have never even seen those spacers. I wonder if washers would yield the same result.
Hey SUPAKAT, do you have a "white bunny" clutch/flywheel setup?
RB20 FW with Z32 NA Clutch. The spacers are pretty thin like .020.
- KA24ETZTM
Had the same problem, put a washer on the bottom bolt, no grinding and starts every time. Running stage 5 z33 with forged DOHC flywheel.
My Original Build Thread: viewtopic.php?f=5&t=35224
- wannaboost?
Awesome. I'll try that. Do you have any idea how thick the washer was?
- KA24ETZTM
No man sorry I don't, I just tried something I had Latin around. So nice to have this fixed...now I'm just worried about the spacer.
