A Feeler For Those Running 14mm Top Feed Injectors
I am currently in the process with a friend at a machine shop of making some 14mm aluminum weld in bungs for my top feed injectors to accommodate the o-ring with out the need of the denso lower cushion or the big o-ring used on the factory side feeds. It will be a drop in weld in bung that will fit your 12mm injector perfectly. I am curious to see how many people would be seriously interested in this product pics coming soon lmk I will get back to you with cost on it.
Cam
- beercandrifter
Re: A Feeler For Those Running 12mm Top Feed Injectors
12mm injectors?
i am used to seeing 11 and 14mm injectors, first i have heard of 12mm injectors
- beercandrifter
Re: A Feeler For Those Running 14mm Top Feed Injectors
so you guys are making something like this?
http://www.summitracing.com/parts/fst-307017/overview/
That is the general idea but it will drop in directly to the intake mani and weld in. But that is some what the concept...our will be maybe 1/4" tall I would guess should have them made this week sometime
Cam
