It wouldnt let me post my picture stating the quota has been met of where my o2 housing is coming in contact with my master cylinder. I had a few ideas but obviously they all either cost a couple hundred dollars or I do not have the equipment to do so. So i am looking for relatively easy applications to try.
The dilemma is that my o2 housing comes into contact with the brake lines. My cheap ideas were to dent the o2 housing in where they meet, try to bend the lines without kinking them. Other more costly ideas were to buy a brake boost delete kit giving me plenty of room, buying another master cylinder that has the brake lines coming out the other side of it, and last and the most expensive is to buy a new exhaust manifold.
Ideas on O2 housing dilemma
- beercandrifter
Re: Ideas on O2 housing dilemma
get a brake line bending tool and move the brake lines if you done want a new manifold (will keep you from kinking the lines)
- superDorifto
shouldn't cost more than $40 to move the lines if you bend them yourself...make a heatshiled and be sure you get enough clearance between the master and the o2 housing.
brakes are important.
If im understanding you correctly, you are talking about your o2 sensor bung/sensor? If so, I would buy a 18 x 1.5 plug and plug it then buy new bung and have relocated. shouldnt be more than $50, plug $4 bung $5-10 welding around $40.
- AFKOUKI
I agree with trackstar. just plug the hole and have a new one welded further down the exhaust. make the parts fit the car, not the car to fit the parts
They sell 90 degree fittings that will thread into the bung. Not sure if this would help your set up but it might be something worth looking into. Also I'm not sure how this would affect your readings iv heard it doesn't affect readings but with the o2 sensor not actually in the down pipe it seems like it would change it atleast a little.
That is a good idea, but you're right, it will change the o2 readings.casey115764 wrote:They sell 90 degree fittings that will thread into the bung. Not sure if this would help your set up but it might be something worth looking into. Also I'm not sure how this would affect your readings iv heard it doesn't affect readings but with the o2 sensor not actually in the down pipe it seems like it would change it atleast a little.
I know this because that is the 'trick' we use for the secondary o2 sensor that 'monitors' the efficiency of the cat.
<< Yuh dun know!!
