E85 timing at 20 psi
ok timing timing timing, just got bigger injectors and turned up the boost, (need more injector still) got bosch 1015's from drift motion highly recommended think i paid $340 for 4, probably gonna go staged with a second set. any ways hitting about 19 psi coming down to 16-17, getting spark blowout, about to close the gaps a bit, how much timing are you guys running at 20 psi on E85 or pump 91 (im on e85) my motor is 8.7-1 comp
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
arp head, main, rod bolts
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
Re: E85 timing at 20 psi
@21.4 psi I am around 15.7*. So @ 20psi I should be around 16* on corn.
@21.4 psi I am around 15.7*. So @ 20psi I should be around 16* on corn. Just close your gaps and grab the steering wheel.
LOL mine is set to about 18.5 i saw any evo10 timing map at 20deg at 20 psi maybe ill pull a couple outsupakat wrote:@21.4 psi I am around 15.7*. So @ 20psi I should be around 16* on corn. Just close your gaps and grab the steering wheel.
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
I had 20* @ 20psi. Ended up lifting my head and blew Cometic HG. I only have 10mm studs so I backed off to be safe.
lol just pulled the plugs and put in fresh bkre7's v power. old ones were gapped at 35 -40 LOL gapped these at 25, plugs were nice and coco, heat band looked good
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
- Kfred
Maybe a little late...
I used to run ~20* at 16psi with e85, but I was running a smaller turbo (50 trim). 16* at 20psi certainly seems like it is in the ballpark, but be careful. All setups are different.
RIP Nate(480sx)...
hahah well i havent lifted my head yet im gonna pull out before i get her pregant, you think detonation caused the lift or too much power?
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
Damn guys, I've been running 16 degrees ramping to 19 past peak tq on 18 psi on a 60 trim .63 t04e on 93 pump in the florida heat forever. Got blowby and ripped my block apart and just have worn rings. Never blew a felpro with the old satrun arp studs and my pistons look great for being from 2006.
built block, sls manifold, 60 trim t3/t04e, rc 750s and nistune
I think I need to re-visit this again. When I lifted the head, I was using this one tq wrench we had. When I redid the setup, I used a new craftsman tq wrench. Regardless of what, I want to take baby steps so I can enjoy her. I ran a 600cc by 3 cars last week from around 50mph to I am guessing 140mph (I know I was close to hitting redline in 4th with j30 diff).ViperGT wrote:hahah well i havent lifted my head yet im gonna pull out before i get her pregant, you think detonation caused the lift or too much power?
Kedbmx made 800whp on 10mm studs. So I had to have had wrong tq on the first time around.
