wideband and narrowband
so i have acquired a innovate lm1 for the cheaps, and was looking at display options. it has 2 programmable output signals, meaning you can emulate the signal going to the computer and to a gauge or whatever you want. i was looking at autometer cobalt gauges and noticed that for a wideband gauge (NOT the actual wdeband, just a display that the wb outputs to) they want $370! im thinking that if you output a narrowband signal (the narrowband gauge is cheaper by far) from a wideband, it should be quite accurate. any input on this would be great.
'91 240sx se abs/hicas/lsd... almost there
'05 SRT4
'89 'yota 4x4 <--DD
'05 SRT4
'89 'yota 4x4 <--DD
- emo_tactical9
But it's only a narrowband. A wideband is 0-5v. A narrowband is 0-1v. A wideband is linear, meaning it's voltage changes with the AFR. A narrowband is not, and fluctuates greatly.
It will be an accurate narrowband, though.
The point of the narrowband output is to use in place of your stock O2. I have been running mine that way for a while.
Guys..... check out www.twosrus.com....... they have a wideband AFR gauge that is $59. I have seen them in person and the look great.... Ordering one next week
- UNISA JECS
This guy is selling the autometer wideband gauge here for $125
http://zilvia.net/f/sale-items/212328-s ... -look.html
Rep/Feedbacks
http://www.zilvia.net/f/showthread.php?t=134726
Z32 E-Brake/Parking Brake Heatshield Assemblys!!!
http://www.zilvia.net/f/sale-items/1667 ... plete.html
Rep/Feedbacks
Rep/Feedbacks
the LM1 guage dosnt have a readout on the computer? i have the PLX M-300 its got both a on computer digital read out and a guage with a DRO and a seeping LED light show.
rebuilt KA24E, port and polish, secondaries removed, stage3 clutch, fidanza flywheel, JGS MM, 3inch cat back with high flow cat, cherry bomb vortex muffler, B&M short shifter,ST sways,nismo brase
KA24ET RB20 turbo, 460cc
- Matt Cramer
- KA-T.org Sponsor
We've got a couple gauges of our own starting from $59. But you can use an LM-1 with a 10-bar display of the sort intended for narrow band sensors by reprogramming its outputs using the included CD. It doesn't have the same resolution as the gauges typically meant for wideband use, but it is good for quick at-a-glance use.
- LigouriRd.
The LM-1 does have a readout for the computer. There is a serial output for updating firmware, downloading the logs and monitoring. I can observe and log my air/fuel ratios and the engine rpm (sorta..its noisy) realtime.dopeassjackson wrote:the LM1 guage dosnt have a readout on the computer? i have the PLX M-300 its got both a on computer digital read out and a guage with a DRO and a seeping LED light show.
Innovate used to sell an simple cheap analog gage to use with the analog outputs. I believe it was something on the order of $50.
They do sell the digital gages separately from the wideband kits but they run about a bill: http://www.innovatemotorsports.com/xcar ... 250&page=1
Since it shows your exact air/fuel ratio it is perfectly accurate.
Most of the narrowband air/fuel gages are merely voltmeters that read between 0 and 1v. You will just have to tweak the analog output so that 14.7 shows up at the correct point on the gage. I haven't seen any that actually show numbers so amount of richness you see will be relative and like said before not particularly accurate.
"There is no such thing as too much boost. You could have too little rod, piston, sleeve, head gasket or timing. But never too much boost."
'91 Nissan 240SX
'96 Nissan 240SX KA-T
'05 Grand Cherokee (4x2)
'85 Honda Nighthawk 450SC
'91 Nissan 240SX
- Matt Cramer
- KA-T.org Sponsor
Yep. They've replaced it with the more modern looking G series of stepper gauges, but we've got a stockpile of the older version:
http://www.diyautotune.com/catalog/prod ... ucts_id=57
