384 whp @ 21 psi
- hotbox240
384 whp @ 21 psi
Finally got my car on the dyno with the new turbo, injectors, maf and 21 PSI.
This was done on a dyno jet dyno I would say it reads a little high.
This turbo is a custom built triple Ball Bearing T3/T4 with a T04E cover, 67mm compressor wheel and a P-Trim wheel on the exhaust. The runs were made with a 50/50 mix of c16 and 94 octane. Obviously alot more power can be found, but I just wanted to get an idea where I was at. Setup as follows:
Built bottom end (Brian Crower Rods, Weisco 9:1 Pistons)
Stock head and cams
850cc Subaru side feed injectors (running wrx injector clips)
N62 Maf
JGS Log Manifold
38mm Wastegate (Recirculated)
Ebay Intercooler and exhaust
EPROM tune + SAFC 2
Methanol Injection coming soon...
- aaronlee97
- Alonso
I strongly recommend upgrading the turbo manifold and to a 44mm wg. I promise you will see, hear, and feel the difference what ar turbine are you running?
Unleash the beast!!!
AWS D17.1 certified
AWS D17.1 certified
- aaronlee97
- hotbox240
The downpipe was upgraded to a 2 - 7/8" diameter. The turbo has a .63 a/r backside on it. There is no doubt that a tubular manifold would probably yield 20% more power.
I'm installing methanol injection when I'm back home again and see if I can make these numbers on pump gas. Maybe a mild set of cams would also help wake it up.
- redpotatoes
- Jordan Gladman
