New dyno Headgasket bye bye
Went to the Dyno today finished tuning, everything was fine drove back home, did some pulls on the highway. But then stopped, started driving again noticed it was overheating a bit. Then Pulled over and looked the reserve tank was 3/4 filled, I had this problem before. Headgasket leaking under high load. So time to upgrade I guess.
608 whp @ 27 lb
608 whp @ 27 lb
Damn. Round 2.
If that does not work, 12mm head studs.
Well that makes sense lol. I hope when you did machine work with the Felpro, that you had the head and deck blocked to MLS standards.Berserker wrote:It was OEM felpro headgasket. Cooling getting pushed into reserve tank on 4th gear pulls.
He resurfaced the head and he prepped it, when I talked to him few months ago he told me that I wont need to redo that whole process if I wanted to install MLS, but I'm going to call him and confirm about that.
I drove 500whp for whole summer. So felpro can hold 500 for a while, because I was beating on the car hard.. But I wanted to push it and see what happens.
Sounds good .
