232 cams vs 264 cams Dyno (Virtual dyno)
- redpotatoes
Did few pulls tonight and got some logs. Here are the results:
The cams ARE NOT DEGREED. I simply did the installation. I was running on my regular map so no tuning was made yet. I was not using my water only injection map which is more agressive. I don't really look at the numbers but more at the powerband changes.
A lot of factors were not the same when I did the pulls like the road conditions, temperature, etc so draw your own conclusion. To me, the change is noticeable. Time to do some degree and see the benefits !
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
Looks good. More area under the curve since it does not drop off.
Awesome! I can't wait to test mine out. I like how they give you much better top end, without sacrifice to the bottom end.
- redpotatoes
I was hoping they were gonna do that and they did. Looking forward to see your results.jholman05 wrote:Awesome! I can't wait to test mine out. I like how they give you much better top end, without sacrifice to the bottom end.
When you degree them, you will move the graph to the left so you should notice a difference.
nice gains across the board, negledgable losses down low at 10#, very nice. yeah, id def like to see you rev it out to 7200ish, tq's dying but that HP still looks strong way up top. i think im pretty much sold. you can own these cams AND JWT gears for $370.... how can you beat that?
By making your own cam gears!
Eazye2000, a very seasaoned and knowledgable member on here,said he went through 7 gears before he finally nailed it. a few thousandths make a bigger difference in degrees than we realize.
Yea but that thou can make it closer to the cam card maybe. That is the only thing I hate about the gears. You are limited to 2.5 degree's.
Hey repotatoes what turbo are you running. The graph looks really close to my old S15 t28 turbo setup at 14psi with bc 264 cams and 9.0:1 Je pistons. But at that time my cams were just dropped in and shimmed correctly no jwt gears.
1995 S14 daily built block nismotronics sr20det Ecu running my ka-t, synergy green S14 5.3l turbo 240sx 1/4 mile traps 135mph on 13psi and dr's.
Holset HE341 Install thread woohoo!!
viewtopic.php?t=48692
http://www.playloudclothing.com/
hes still on the 2871 from his sig. def a nice curve outta that snail.
- redpotatoes
Running a GT2871R .86, stock block.
I will order some sprockets soon.
update?
Update...
Fairly similar results, think I could get one of your .csv files to compare back to back?
viewtopic.php?p=494371&highlight=#494371sytfu_S14 wrote:Have you tried doing a 3rd gear pull to compare with your 3rd gear pull you did with the 232s? I felt a big difference goin from the 232s to these 264s. I'm on 10psi with a t2 3076wg
- redpotatoes
Sure no problem, I will send them to you.jholman05 wrote:Update...
Unfortunatly, my car is stored for the winter. I haven't done any other pulls or tune on the setup.
I just did the same with mine this past weekend
Cool send it over, I think you have my email.. if not try jesseholman@hotmail.com
- redpotatoes
Interesting plot of my setup on 12psi vs. redpotatoes on 14psi... pretty similar curves
- redpotatoes
Nice !
You need to do a 14 psi run and I need to run a water injection tune !
potatos! fix your links!
- redpotatoes
Fixed !
huh i checked on 2 computers and both pic in your op say "sorry person moved or deleted this image" sup with my sig, cant see it either?
redpotatoes wrote:Haven't made any changes to my links. Looks like you have problems too if I look at your signature. Seem too be generalized.
Your original links don't work in post number one for me either. His sig looks fine to me...
- redpotatoes
My bad, I looked from my phone and links were not showing.sdaigle240 wrote:huh i checked on 2 computers and both pic in your op say "sorry person moved or deleted this image" sup with my sig, cant see it either?
Fixed !
Re: 232 cams vs 264 cams Dyno (Virtual dyno)
Nice to see actual numbers. 20hp WOW!
