6262 @30 psi
6262 @30 psi
Here's my dyno from tonight. I only have the graph from the uncorrected numbers but sae power was 659 hp and 599 ft lbs.
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Cxracing fmic
Proefi pro128, e85 flex fuel
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Nice car...great power...
Re: 6262 @30 psi
nice hows the traction with the boost coming in like that lol
Re: 6262 @30 psi
Thanks guys. Traction haha there's none if the car is under 100 mph lol.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Very nice setup!
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
Re: 6262 @30 psi
Thanks bro !! I actually dynoed it again at 32 psi but don't know if I should start a new thread for that.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Fantastic!! Any in car vids?
Re: 6262 @30 psi
Great numbers. Give me hope that i will make over 600whp on my gtx35.
R.i.p. 97 s14
96 s14 ka-t
Re: 6262 @30 psi
Very nice numbers,makes me wanna finish my 6266 build even more.
Re: 6262 @30 psi
Thanks bro I have no in car vids as of yet. Need a passenger to go with me it's hard enough controlling it but to try and shoot a video at the same time lol.Marcus wrote:Fantastic!! Any in car vids?
Thanks bro your build is sick!!! You should have no problem hitting 600 assuming your on e85.turbo2nr wrote:Great numbers. Give me hope that i will make over 600whp on my gtx35.
Thanks bro you should finish your build it looks like an awesome one. And so I can see the potential of that 6266. I love my 6262 but I think I'm at or close to the limit. But the spool up is awesome plus the power potential of this turbo makes it a perfect turbo for the ka IMHO ,but my experience has been this turbo with e85.e85 helps spool bigger turbos because it has more exhaust velocity.arob987 wrote:Very nice numbers,makes me wanna finish my 6266 build even more.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Damn Chris, Congrats on the power. I remember when you first bought this car. Car has come a long way that's for sure. Looks so nice now.
1995 S14 daily built block nismotronics sr20det Ecu running my ka-t, synergy green S14 5.3l turbo 240sx 1/4 mile traps 135mph on 13psi and dr's.
Holset HE341 Install thread woohoo!!
viewtopic.php?t=48692
http://www.playloudclothing.com/
Re: 6262 @30 psi
Thanks James yup car has come a long way from when you dropped that stock motor to me lol. my boy duncan351( Duron) and My boys at d3 performance engineering guided me in the right direction.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Very Nice numbers! What headgasket/headstuds are your running? And whats done to the head? If you dont mind sharing
Re: 6262 @30 psi
It's a cosworth head gasket, 11mm l19 head studs, head is ported and has dual valve springs that's about it.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Thanks for the info this is the turbo I ordered hoping for around 700
Re: 6262 @30 psi
what method did you go about installing the 11mm l19's ? i dropped in buckets the other day and found that 2 of them will not go in smoothly because my head was warped :/. so of comes the head. i regret using a cometic and arp 10mm's, c16 would seem alot more expensive when im only able to go 5 or 6 psi over pump fuel limits.
Re: 6262 @30 psi
I time serted the block for the 11mm head studs. I did them myself but the time sert kit I bought was 400 bucks. But it worked great.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
holy cow. how much furthur do you plan on pushing the boost? i was thinking of just special ordering custom l19 10mm studs specifically for the ka, it would work out very similar in price, and im sure they would still be very reliable at 30psi.
Re: 6262 @30 psi
32 or 33 psi is probably all I'm gonna bring it to. I already have other issues like traction and transmission issues. I just run around on 20 psi . I haven't needed more than that to be any car I've raced on the street. I save the high boost for runs I have set up with bigger fish aka built fast cars lol .
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
yeah. i cant wait to see my car running ! fortunatly i have 2 ka transmissions to kill. and traction is a big problem im sure, i plan on rolling on some slicks though, so more on the transmission side for me haha.
Re: 6262 @30 psi
Nice numbers. Can you post a link to the timesert kit that you used?
A1 Technologies used to make 10mm L19s for the KA. Unfortunately, they stopped making them. I e-mailed them a while back to see if they could make a custom set and they never even responded.ka240de wrote:holy cow. how much furthur do you plan on pushing the boost? i was thinking of just special ordering custom l19 10mm studs specifically for the ka, it would work out very similar in price, and im sure they would still be very reliable at 30psi.
Re: 6262 @30 psi
http://www.mechanicstoolsandbits.com/he ... p-213.html
This is the website and the kit I ordered. And it has free next day shipping . It really did come in the very next day. Made the morning delivery was pretty pleased with this company. I had to modify the alignment plate with a spare head gasket I had . But I did my time serts with my block still in my car. This kit literally has every thing. It even has a sleeve that you insert into the plate to make sure the drill bit and tap go in straight. Very good kit but it's pricey but then again you got to pay to play right lol .
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
Personally I used I believe it was rb20/rb25 studs (have the box somewhere in the garage) drilled and tapped the block no timeserts.my machinist put it on a machine that levels the block and drills it(not sure the name of it) then tapped it cost me 150 dollars,he said there was plenty of thread and wouldn't be a problem.I've torqued the head down 2 times no problem have put around 1500 miles after the first time and no problems.I also used cometic gasket lol but he resurfaced the block and head for it and it sealed fine Only pulled head because a valve fell when I was doing a couple valve seals.
Re: 6262 @30 psi
see id be curious about that, but its also nice to do it in the car say i wanted to do the upgrade next season you know.
Re: 6262 @30 psi
Being able to do the timeserts with the motor still in the car would really save a lot of time and hassle. Thanks for posting the link.
May I ask where you bought your head studs? I'm assuming you're using the 11mm L19 Evo head studs?
- 1991240sxhatch
Re: 6262 @30 psi
nice car, is there a reason ur still running the stock intake?
Re: 6262 @30 psi
I honestly don't remember which website I bought them from but they are for an evo8/9 . Yes 11mm l19 head studs.adamky wrote:Being able to do the timeserts with the motor still in the car would really save a lot of time and hassle. Thanks for posting the link.
I'm actually debating that right now. I've been using the stock intake for. Kw because it's what I had lol. But I'm trying g to debate if it's worth it to upgrade. I haven't really seen another power curve here like mine but that's not to say there is t gonna be a gain from it.i just want to make sure it's gonna benefit me to change the intake out to a shorter runner bigger plenum .1991240sxhatch wrote:nice car, is there a reason ur still running the stock intake?
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Re: 6262 @30 psi
have you any concerns with the l19 material and its vulnerablilty to rust ? im not going to say where because they only have one set left, but i found a set of 10mm l19 studs for the ka, drop in, priced good. not sure how much ill benefit but id like to hold a safe 28 psi on a similar sized turbo.
Re: 6262 @30 psi
Awe, come on and tell us. I won't swoop in and grab them up, I promiseka240de wrote:have you any concerns with the l19 material and its vulnerablilty to rust ? im not going to say where because they only have one set left, but i found a set of 10mm l19 studs for the ka, drop in, priced good. not sure how much ill benefit but id like to hold a safe 28 psi on a similar sized turbo.
