sohc dyno guess.
sohc dyno guess.
Hey. Used to be a member here but got out of the car scene for abit. Couldnt find my old account. Just finished putting together a pretty solid sohc.going to be taking it to a dyno shortly but wondering what you guys think this setup should make.
-fresh built motor. Stock internals.
-gladman t25 manifold
-sr t25 turbo
-fmic
-rx7 500cc injectors
-z32 maf
-colt cam tf1 camshaft
-2.5 downpipe to 3"
-butterfly valves removed
-enthalpy tune.
-walbro 255.
Plan on running the t25 at whatever it can push. Hoping to get an efficient 12psi out of it.thanks in advance! Cant wait to get it on the road.
-sr t25 turbo
-fmic
-z32 maf
-2.5 downpipe to 3"
-enthalpy tune.
-walbro 255.
Re: sohc dyno guess.
235whp - 248tq Good luck bro!
Thanks. Hoping to squeeze a little more then that but we will see
Don't forget to post back and prove me wrong bro!!!!
good luck, you might make a little more trq but the hp will be lacking on the top.. t2 flange.
Yeah the turbos way to small but its what i have at the moment.hoping it will keep up with the fmic,exhaust,12psi sr20's. Thanks for the input
Why don't u look for a t3 off a ford thunderbird or z32? you'll def beat sr's on 12psi
Basically just wanted to get it up and running for summer
Purchased the car with everything just had to put it together. If i was to switch to a t3 turbo id need a new manifold and possibly downpipe and retune so its not worth it for me right now. Next winter it will get new injectors,turbo,mani and tune. Forgot to add it has white bunny clutch and arp stud kit aswell.i know not hp adders.
I want to see the results!!
I'm guessing you be somewhere between 245-270 on 12 psi. I made 252 on 10psi with a t3 .50trim
89 Ka24e-t
completely stock
49k miles
550cc injectors
z32maf
GSP.50 trim
38mm WG
10 psi
260wtq
completely stock
49k miles
550cc injectors
z32maf
GSP.50 trim
38mm WG
10 psi
260wtq
Max hp on T25= 240whp
Enthalpy tune for 91 octane I'm guessing 223whp 228tq
'91 S13
Built, balanced KA-T
- street_240sx
You can make a little more than 234 on a t25 it just won't last long.
03 evo8 gsr: stroker 2.3
