74 datsun 620 dynoed at ssautopower in manteca, ca for a datsun dyno day event. wideband was not synced with nismotronic correctly so its been running about a afr point richer in the tune.. oh well, better rich than lean right lol. everything is all good now though.
ka24de setup:
block bored 0.020 over, decked
stock head, cams, springs, etc. valve jobbed, decked
rotational assembly balanced
arp heads and mains
wiseco 9:1 pistons
eagle h beam rods
stock crank
xcessive intake mani w/xcessive top feed rail and stock tb
id1000cc injectors
bosch 044 pump, -8 feed -6 return
cxracing top mount manifold
precision pt6262 turbo, 2.75" open dp
turbosmart 38mm gate, 14psi spring, open dump
running on a speed density nismotronic setup tuned by john at nismotronic
datsun 620 ka-t 364.3whp @ 14/15ish psi
Re: datsun 620 ka-t 364.3whp @ 14/15ish psi
That must be fun to drive. How hard is to keep it straight on the road? Light car with short wheel base = crazy ride.
not too bad with both hands on the wheel lol. suspension is all original from 1974, so handling is not all that great. in the process of upgrading to a d21 front hub/ball joint conversion along with front coilovers and new rear leafs. should feel better after that
