346 whp and 349 ft lb @ 15 psi. built ka with hx35
- 90 mm cp pistons. Pretty sure it's 8.5:1 cr
- eagle rods
- bc 272 cams, and springs (cams are not degreed, just turned back a couple few teeth on stock cam gears)
-id1000 top feed injectors
- radium fuel rail
- aeromotive fpr and stealth 340 pump
- clutchmasters fx400 6 puck Clutch
- stock intake mani
- ls coil packs w/msd 8.50mm spark plug wires
- full race twin scroll exhaust mani
- tial 50m bov
- tial 44mm wastegate
- megasquirt v3
- hx35/40 with 12cm^2 twin scroll exhaust housing
- nismo 2 way lsd
- stock tranny with over 300000 km and 7 years of pretty good abuse.
-94 pump gas
- bkr7e plugs gapped at .029
-approx 3600 ft above sea level if that makes any difference
Definitely forgetting a few things. Will post up as I remember
- eagle rods
- radium fuel rail
- stock intake mani
- tial 50m bov
- megasquirt v3
- nismo 2 way lsd
-94 pump gas
- hotbox240
Re: 346 whp and 349 ft lb @ 15 psi. built ka with hx35
Looks good, where ya located?
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
Looks good. When you gonna turn it up to 25psi?
Looks good. When you gonna turn it up to 25psi? Sweet spot is around 28psi on an HX35.
I'm up in calgary alberta
won't run that much boost unless I switch to race gas. I keep taking out bearings and rods when I make lots of boost on pump fuel. I'm more than happy with it. It hauls like a freight train. I was hoping for 375-400 but my tuner and I decided to stick with a fairly conservative and safe tune until I run race fuel.
Great numbers. Great to see another holset mafia member! Would you mind sharing your .MSQ?
Kill3rwill wrote:Great numbers. Great to see another holset mafia member! Would you mind sharing your .MSQ?
Thanks haha. I love the holset.
msQ?
That's the tune file megasquirt uses. I'm curious how your timing map looks as it's hard to source a Dyno tuned map, all the ones available for reference are just people's guessing games
- mattheripper
Looks great man, I'm in Lethbridge, stoked there is another holset ka-t around!
R32 KA24DET HE341 MEGASQUIRT DIYPNP S13 suspension 18x10/12
Click it >>>> viewtopic.php?t=56032
- mattheripper
Oh fetch in a rhd too even eh? I'm interested in how early you start seeing boost with the twinscroll? I'm wanting to go with the fullrace mani as soon as I can, but want to make sure its worth it. Looks like right around 3500?
edit:
Actually just found your other dyno after looking for another hx35 comparable and it doesn't look like you gained too much spool up with the twin scroll jazz,
http://www.ka-t.org/viewtopic.php?f=3&t=58199
Is that right? I'm surprised you weren't twin scroll then too because it looks way good for a hx35. Let me know, super interested in your experience.
edit:
- hotbox240
Street racing scene big in cow town?
I don't know. Ive been out of the loop in the car scene for a good year and a half, too busy workin. I don't street race. Besides fooling round with a couple few buddies. I do know it's gone up since they got rid of out race track a few years ago and the closest place is Edmonton 3 hrs away.hotbox240 wrote:Street racing scene big in cow town?
https://youtu.be/_6Fu58C2pyU
Here's another pull, increased boost up to 16-17 psi and played with the timing a little bit
- torquefreaks
sick as ***** dude! im repping a hx40 ka on Vancouver island!
