684/572Tq 33psi 6766 Stock intake
- KA-T.org Featured Ride
It was an ambient 112* in the shop on the dyno which was ridiculous but fun. The head gasket really let go after 650hp pull but my water temps were still in an acceptable range but starting to go up which concerned me but I turned the boost up a little more and hit the 684 point then water temps started shooting up quick so I shut the engine off. Anyways, I'll pull the head and prep my surfaces to install an MLS gasket along with my short runner intake manifold.
Setup:
Wiesco Pistons (Over the Shelf ones)
Eagle Rods
L19 11mm Head Studs
Stock Head Gasket
Upgraded Valves & Dual Valve Springs
Ported Head
BC V3 Cams degreed to Intake 2.5* Retarded / 8* Advanced Exhaust
67/66 1.00 A/R T4 Twin Scroll Twin Wastegate
E85
Stock Intake
843whp @ 40psi
761/596 Tq 33psi 6766
http://www.enginerebuild.net
- hotbox240
Re: I found the limitations of the stock headgasket
Looks good. How much boost? Since switching to a tubular exhaust manifold and Xcessive intake manifold I've given up a god awful amount of torque.
Re: 684/572Tq 33psi 6766
33psi, the manifold I'm installing has longer tubing than xcessive so I'm hopping my torque drop isn't too bad. But I'll try throwing some more timing under the curve to help keep it peppy.
843whp @ 40psi
Congrats old school. Well that killed the can't make power with the stock intake bs. Any video?
Nice work. Keep it up man.
Badass. Time to update your sig!
decided to go ahead and build the high compression motor and install an intake I bought a while ago. Its nice looking manifold with high dollar parts but terribly engineered, anyways after redesigning it to work on my car it all is turning out pretty well. I had a few bugs so had to cut my tuning short but here's where I stopped.
I also adjusted my cam timing a little which seems like the motor liked it.
Here a complete picture of the graph.
843whp @ 40psi
does it feel more responsive with high comp? The curve looks nice and linear. Nice numbers!
R.i.p. 97 s14
96 s14 ka-t
yes, I didn't loose much responsiveness at all with the new intake like most do. Feels very close to stock off boost and spools fast and very linear.
843whp @ 40psi
- Greaser
- Master of Knowledge
Do you have all the .drf's? (the raw dyno files) if so gimme, i'd like to overlay some stuff. If you dont ask the shop to email them, they're small.
What cam timing adjustments did you make?
send me the cal file for the pro efi i wanna see something.
mrdtuner@hotmail.com
greaser@cox.net
greaser@cox.net
Cam timing on my V3's are intake straight up, exhaust advanced 7.5*
I'm not running Pro Efi. The owner of ProEFI Jason and his brother are arrogant pricks that I will chose to go another route and have no regrets.
Greaser wrote:Do you have all the .drf's? (the raw dyno files) if so gimme, i'd like to overlay some stuff. If you dont ask the shop to email them, they're small.
greaser@cox.net
843whp @ 40psi
- Greaser
duncan351 wrote:Cam timing on my V3's are intake straight up, exhaust advanced 7.5*
greaser@cox.net
ha, called it didnt i.
yeah i figured you went the opposite when the midrange looked lazy. I wouldnt steer you wrong, try it my way and overlay the graphs.
Greaser, you're still around?Greaser wrote:duncan351 wrote:Cam timing on my V3's are intake straight up, exhaust advanced 7.5*
greaser@cox.net
Friends don't let friends buy knock-offs.
- flip240
wow, old schoolers in this thread!
Nice numbers Duncan! Keep it up!
My setup: KA24DE-T
My setup: KA24DE-T
Wow, nice smooth curve there boost spooling up nice and smoothly starting after 4k rpm. Glad to see the cams working out for ya with some fine tuning, JWT cam gears and getting the it just close enough.
'95 240SX; BW S366; S257 SXE; Kelford 272/272
What's up Alan. Glad to see you still chime in from time to time. Have you had time to get your car going? I'm trying to get alot of the guys back together to cruise. Yea, made some more adjustments and car runs even better.
843whp @ 40psi
Not yet Duron, been sitting on this Z33 transmission swap and lower rear axle ratio... got lots of work to do there, I'm done with the stock KA 5 speed. I've changed the intake side of my setup (XS manifold, custom throttle body), gotta do some wiring work to get the TPS working. May go to bigger fuel injectors, I'm running the AEM Series 2.
I did the z32 trans swap along with rear axle and diff axle ratio change and love it! Well worth the effort and money. No more worries about breaking stock tranny's anymore. The flex fuel Is very nice, no more over priced race gas.
843whp @ 40psi
were in a group buy for z33 adapter plates for $250.. need one more to join. nice power btw
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
arp head, main, rod bolts
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
