415tq 431hp @21lbs
https://m.youtube.com/watch?v=qb6NMHXeRSI
S256 AGP @21psi
S256 AGP @21psi
ONLY REAL MEN STAY KA
- hotbox240
Re: S256 AGP @21psi
Looks like fun. This on pump gas?
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
Re: S256 AGP @21psi
Nice numbers! What compression and is this a t4 flange unit?
-Stock cams?
-Stock cams?
Re: S256 AGP @21psi
Interesting for sure, what hotside?
Also, what are your other specs. I'm running the 256sx with the .63AR myself.
Re: S256 AGP @21psi
looking for a s366 t3 flange
Re: S256 AGP @21psi
His build list says Crower 264's and JWT gears.NateDogg wrote:Why your peak HP RPM so low?
S14 cams?
viewtopic.php?p=529135#p529135
Does it hold boost steady until redline, or does it drop off? I'm also curious if the cams have been timed and if so, what they are set to.
