Page 1 of 1
S256 AGP @21psi
Posted: Thu May 19, 2016 5:38 pm
by rtm240sx
Re: S256 AGP @21psi
Posted: Fri May 20, 2016 10:02 am
by hotbox240
Looks like fun. This on pump gas?
Re: S256 AGP @21psi
Posted: Fri May 20, 2016 10:54 am
by rtm240sx
Yeah on 93
Re: S256 AGP @21psi
Posted: Fri Sep 23, 2016 6:19 pm
by i_slide
Nice numbers! What compression and is this a t4 flange unit?
-Stock cams?
Re: S256 AGP @21psi
Posted: Tue Sep 27, 2016 5:48 pm
by tuzzio
Interesting for sure, what hotside?
Also, what are your other specs. I'm running the 256sx with the .63AR myself.
Re: S256 AGP @21psi
Posted: Sun Oct 02, 2016 5:18 pm
by SIL8D
looking for a s366 t3 flange
Re: S256 AGP @21psi
Posted: Tue Dec 20, 2016 5:12 pm
by rtm240sx
Rear housing is .75A/R divided housing.
Re: S256 AGP @21psi
Posted: Fri Jan 27, 2017 11:02 am
by NateDogg
Why your peak HP RPM so low?
S14 cams?
Re: S256 AGP @21psi
Posted: Sat Jan 28, 2017 10:25 pm
by adamky
NateDogg wrote:Why your peak HP RPM so low?
S14 cams?
His build list says Crower 264's and JWT gears.
viewtopic.php?p=529135#p529135
Does it hold boost steady until redline, or does it drop off? I'm also curious if the cams have been timed and if so, what they are set to.
