S13 ka24det 471whp 391 tq t3/t4 57 trim turbo
godrifttoday
Post by godrifttoday »
Jason turbo
Jason turbo
Jason turbo
Jason turbo
S13 ka24det 471whp 391 tq t3/t4 turbo 57trim
Fuel:91 and meth (aem methonal kit )
Tuner:koji @ auto talent ca.
Low Boost 14-15 psi 400hp
High boost 20psi 471hp
Cams 272 /oversize valves all valves have been shimmed to spec .10 and .08
Xcessive intake manifold/ turbo manifold
Port and polish head
Cp Pistons 9:1 eagle rods
Aem v2 ecu
Turbo t3/t4 57trim
godrifttoday
PR0D1GY
Re: S13 ka24det 471whp 391 tq t3/t4 57 trim turbo
Post by PR0D1GY »
What size meth nozzle and what % meth mixture. This makes me nervous to put my holset on dyno with meth
godrifttoday
we used the largest nozzle that aem provides with the aem kit. I bought premix "boost juice" by snow performance so it's 49 meth /51 water. And we started the meth at 5psi
godrifttoday
cham
Post by cham »
What t3t4 turbo are you using and what are the specs?
godrifttoday
T3/t4 57 trim
godrifttoday
hotbox240
Post by hotbox240 »
How come it says flywheel torque/power on the dyno sheet?
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
tuzzio
Post by tuzzio »
How much timing do you run at 20psi? I'm curious how much more you can run on meth vs my pump gas 93.
