Z32 trans
All about KA-T Drag Racing. Bragging, Timeslips, Results, Questions, Whatever
Z32 trans
Postby nissy92 » Mon Oct 17, 2016 11:35 am
What power levels are stock z32 5 speeds good to? It will be going into a drag car and the only upgrades I've found are the ppg setup
nissy92
Re: Z32 trans
Postby adamky » Tue Oct 18, 2016 9:56 am
700.. 800.. 900... really depends on how you use/abuse it, but they are very stout transmissions.
Re: Z32 trans
Postby modulation » Tue Oct 18, 2016 3:03 pm
What amount of torque does the ka24de transmission start having problems at?
modulation
Re: Z32 trans
Postby adamky » Tue Oct 18, 2016 5:29 pm
The only one that comes to mind immediately is kedbmx. He destroyed the KA 3rd gear rolling into the throttle with good tires and lots of traction. He was around 500-550whp back then, IIRC.
This is a picture of a SR20DE vs a Z33 transmission, but the SR trans is the same as the KA, and the Z33 gears are similar in size to the Z32 gears. The difference in gear size alone is ridiculous.
Stock trans
Z32 trans
Re: Z32 trans
Postby nissy92 » Wed Oct 19, 2016 1:29 pm
Ok thanks for the reply.i launched my car on toyo r888s 1 time and bye bye trans.ill post pics when I pull it and get it apart lol
nissy92
Re: Z32 trans
Postby RosadoRacing » Fri Oct 21, 2016 9:40 am
I broke the stock trans after a 11.6 pass at 14psi 440whp 350tq. it did last on The dyno when i made 660whp but the launch on slicks broke on the driveshaft side. I since been running the z32 no issues10.5 passes all day
RosadoRacing
Re: Z32 trans
Postby s14fiend » Sun Oct 30, 2016 6:05 pm
RosadoRacing wrote:I broke the stock trans after a 11.6 pass at 14psi 440whp 350tq. it did last on The dyno when i made 660whp but the launch on slicks broke on the driveshaft side. I since been running the z32 no issues10.5 passes all day
At what RPM and what differential gear?
s14fiend
Re: Z32 trans
Postby RosadoRacing » Tue Nov 01, 2016 11:40 pm
I crossed the line around 7300rpm with the 4.08 gears. I now have 4.11 gears with a slightly taller tire a true 26" before i had a 25.8". Im hoping to hit 155mph at 8000rpm.
RosadoRacing
Re: Z32 trans
Postby Stevens14s » Thu Nov 03, 2016 3:58 pm
What Gear
Stevens14s
Re: Z32 trans
Postby RosadoRacing » Fri Nov 04, 2016 10:04 pm
4th gear...
RosadoRacing
Re: Z32 trans
Postby thomasc016 » Fri May 31, 2019 12:26 pm
modulation wrote:What amount of comparateur assurance chat torque does the ka24de transmission start having problems at?
This is my first time here and I just want to say that I’m very happy to be here and to share my opinion.
Thanks!
thomasc016
Return to Drag Racing
Users browsing this forum: No registered users and 13 guests
