Definately 400whp.....
- nissanfanatic
Well I made 5 passes trying to get my boost under control. It kept spiking to 1 bar and dropping to .8 or spiking to 1.3 and dropping to .9 ect ect. So, I borrowed a MBC from a friend of mine. Put it on, same thing..
Last night I pulled the wastegate to find out that my lower nipple was screwed in too far and that was hitting the lower part of my diaphram. IE, the wastegate was staying open about .25". Fixed that.
Today, first pass, I was only hitting .85kg/cm2 even at 1.0kg/cm2 target boost and with 70% DC. I put the MBC on.
Finally set it up good and got a nice-ass run.
R/T-----------.465
60'-----------2.146
1/8-----------8.544
MPH----------90.18
1/4-----------12.675
MPH----------122.38
That was spiking to 22psi and holding steady at 20psi. This setup is NICE on the street.... I was running approx 50% 100 octane, 50% 93 octane. I definately say that is over 400whp. My car is stock weight minus trunk interior stuff and A/C.
R/T-----------.465
60'-----------2.146
1/8-----------8.544
MPH----------90.18
MPH----------122.38
- jpadilla12
- nissanfanatic
- driftking777
cory thats deep 11's with traction. get some 5 lug hubs and ill bring you my welds/DRs!!!
i been upping the boost lately too, i got it up to about 18, then after adjustments i hit 20, but my boost gauge is only a 20psi one so i think it was hitting 21 or 22 and it tried to detonate on me, felt good though. these enthalpy tunes are badass, i just need some 100 octane and then i think im gonna go for a 20 psi run on the DRs next month at a track day.
- nissanfanatic
Yes.driftking777 wrote:you still running on your stock tires, and open diff?
Yea I saw a few cars doing 11.1's at 120-121mph. Miami240 did low 11s at 123 or so too.ispypsi wrote:cory thats deep 11's with traction. get some 5 lug hubs and ill bring you my welds/DRs!!!
20psi is definately fun..!!
- Cobra723
nice mph, ur 60' can use some work...
1991 Nissan 240sx - awaiting 1jz install
1996 Toyota Supra TT - (1 of 27)http://www.cardomain.com/id/cobra723
- nissanfanatic
Nope, no lightweight flywheel. Yes, stock S13 cams.
There is nothing more I can do. By feel, I can tell I am right on the edge of spinning each launch. I am handicapped by lack of spending money on tires, rims, suspension, and a limited slip. None of which I ever plan to use as an excuse. If anyone notices, I only say this when someone asks why my ET sucks so bad.
As before, its a street car and I am there for MPH.
- Cobra723
oh thats a open diff? wow definitely not bad at all then...
- nissanfanatic
- nissanfanatic
- jpadilla12
- nissanfanatic
- KA-T.org Featured Ride
- turbo240ka24det
nissanfanatic: what happened to your 1/8 mile trap speed? I certainly dont doubt your run but I have never seen a car (either boost or n/a) gain over 30mph between the 660' and 1320' at your level of performance. You should be able to pull more than 90mph!
1991 240SX, hatchback
-16.2 @ 84mph baseline run before turbo
Sup Corey, just had the exact same problem with boost spiking. The problem only started since summer time. I fixed the problem by relocating my boost solenoids to the front of the engine bay near my air filter. This cured the problem and I was able to turn the gain up on to make the turbo more responsive. I believe the culprit was the heat for me. I hope this maybe helpful for someone. It worked for me.
843whp @ 40psi
761/596 Tq 33psi 6766
http://www.enginerebuild.net
- nissanfanatic
- turbo240ka24det
- nissanfanatic
- nissanfanatic
