1/4 mile 13.594@109.76mph
All about KA-T Drag Racing. Bragging, Timeslips, Results, Questions, Whatever
redpotatoes
Post by redpotatoes »
I decided to try out my car on the 1/4 mile for the first time. Did 6 runs and my best was:
0.952 - Reaction
2.327- 60 ft
109.76 - MPH
13.594 - ET
I am sure I can do much better, if I was not burning the whole 1st gear and part of the 2nd and a better reaction time of course :). This was done on heavy 22lbs 5zigen Typhoon 17" with Toyo T1R 225/45/17 at 27psi. Cold condition, tonight it was 45 Fahrenheit / 7 celcius.
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
Berserker
Post by Berserker »
Not bad you proly can hit 13 flat with better 60 foot for sure. Good job.
s13grady
Post by s13grady »
damn. you are definitely still spinning alot arent yo.
you are trapping at almost 110. your car is capable of high 12 second passes all day long as it is. you get under a 1.9 60 foot and you will be around 12.5 in the 1/4.
you got to work on that traction issue.
92 s13 ka24det sc61 project.
street trim sleeper
Trippen
Post by Trippen »
Nice runs....What RPM are you launching at. At what tire speed/ wear rating?
Trippen-
-Boost is like a bad habit the more you do it the more you want it.-
89 240sx se Hatch-NA RS*R race springs w/AGX's
92 240sx se Convertible-(Wifes Car) NA , Tanabe Coilovers..
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite. 275.5 tq 246hp @14psi
redpotatoes
I tried different launches, 3500 and 4500. Does the same thing I am spinning like a mofo. I need to control my foot on the pedal...
Tires details: Speed Rating Y
turbonola
Post by turbonola »
i ran 13.4@102mph on a blow t28
you can do better. if you can get a 2.1-2.0 60ft you can run 13.0-12.9 easy
11.65@118 1.64 60ft
fos240
Post by fos240 »
why are you guys telling him good job? that's horrible. your time is horrible for those trap speeds. keep practicing. btw, what kind of clutch are you using? if it's a puck clutch, you probably won't have much success getting the times down on street tires. (too hard to slip a puck clutch.) you'll need better rubber under the car.
frankie
Post by TinyT »
fos240 wrote:why are you guys telling him good job? that's horrible. your time is horrible for those trap speeds. keep practicing. btw, what kind of clutch are you using? if it's a puck clutch, you probably won't have much success getting the times down on street tires. (too hard to slip a puck clutch.) you'll need better rubber under the car.
frankie
they are telling him nice trap speed, and to work on his 60'. first step, go to the track when its not 45 degrees.
